Results 1 to 7 of 7
    New ROGer Array
    Mar 2014
    3
    Raid 0 with 2 ssd's and using a RAIDR IN HybriDisk mode
    Hi all.
    I am currently working on building a system with two samsung 256gb SSD's as a raid 0. I also have a RAIDR express card.
    I am wondering if it is possible to use the RAIDR IN HYBRIDISK mode to get a good speed. I have a maximus gene mobo and I am using an i7 Haswell. Should I be concerned with this configuration?
    Thanks
    imMortal Kombatant Array Myk SilentShadow PC Specs
    MotherboardASUS Rampage IV Formula
    ProcessorIntel i7 3930K
    Memory (part number)8GB Corsair XMS3 1600
    Graphics Card #1ASUS Radeon 7970 3GD5
    Sound CardROG Xonar Phoebus
    MonitorSamsung SyncMaster SA300
    Storage #1Corsair Neutron 128GB
    Storage #2Seagate 2TB
    CPU CoolerCorsair A50 Pro Air Cooler
    CaseBitFenix Merc Alpha
    Power SupplyThermaltake Litepower 700W
    Keyboard Alienware TactX Keyboard
    Mouse Tesoro Gandiva H1L
    OS Win7 Ultimate x64
    Myk SilentShadow's Avatar
    Jan 2012
    266
    5,241
    What the heck is Hybridisk? if you mean RAIDing all 4 together it won't work all that well, as the RAIDR is 2x120GB's in RAID and your Samsungs are 256GB's
    New ROGer Array
    Mar 2014
    3
    Explanation of ROG HybriDisk
    I am talking about a software feature that is talked about on the product page fro the RAIDR. I also miss-spelled the name.
    It is ROG HybriDisk. I also understand that the RAIDR is two 120GB M.2 (NGFF) drives.
    Thanks
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,037
    Hello
    A couple of things here. The RAIDR Express uses two SandForce SF-2281controllers in a RAID configuration by the use of a Marvell 88SE9230 RAID controller. There is nothing that is M.2. Secondly why would you want to cache a SSD RAID0 array with the RAIDR. That would serve no purpose.
    New ROGer Array
    Mar 2014
    3
    Follow up
    All,
    I have a better understanding of what is going on now. My Raid 0 with the 2 SSD's will be a separate array. I will install my OS on the RAIDR, and then use the software utilities that came with it to maximize its performance. My original idea was in fact to have a cache for a raid 0, however I see now why that would be counter productive. Maybe in the future PCIe based storage devices will be able to talk to each other allowing something to the effect of raiding multiple RAIDR type designs. Or maybe an easier way of saying it might be when 8+ lane devices are available and affordable.
    Thanks
    New ROGer Array
    Mar 2014
    1
    RAIDing RAIDRs
    One of the advantages of the RAIDR over straight SSDs is that RAID0ing SSDs maxes out the SATA bus after 2 drives. RAIDRs as reported by JJ in an ASUS youtube scale in thoughput as you add RAIDRs up about five of them. So with five you would in a way be getting 10 lanes, since each RAIDR is a RAID0 of 2 120s.
    Check this: http://youtu.be/Wfx4g4YG-pk?t=19m54s
  7. #7
    ROG Enthusiast Array
    May 2013
    30
    How do you put them in raid? Software (asus?) based?
