03-13-2014 07:59 AM - last edited on 03-05-2024 11:31 PM by ROGBot
03-13-2014 08:05 AM
03-13-2014 08:08 AM
03-13-2014 08:16 AM
03-13-2014 08:30 AM
PowerOver9K wrote:
All video cards hang off the motherboard and the rear PCI slots. Are you saying it's still pretty flimsy?
Antronman wrote:
I'm pretty sure the DCII cards come with a backplate...but not certain. I would buy one.
Chino wrote:
With modern graphics card being the size they are, it's normal to experience some sagging. That is why some manufacturers like Cooler Master make GPU holders.
Scythe makes a thin piece of wire that they call Ninja wire that helps reduce the sagging.
03-13-2014 10:17 AM
03-13-2014 10:23 AM
03-13-2014 10:49 AM
Chino wrote:
The backplate helps but do not remove the complete sagging.
Zka17 wrote:
In the regular cases, where the VGA is mounted horizontally, sagging is very common problem… bigger the VGA, bigger the sagging will be - however, it should not be so sensitive as you say… if light bumping disconnects it, the you have a seating/power connection problem!
As Chino said, backplates help in some extent, but won't be perfect… I kinda like that wire thing…
The best solution though is to use a case where the cards are mounted vertically… - that's why I like the Test Bench-style cases...
03-13-2014 01:19 PM
Hmong_Xiong wrote:
I'll try to seat it in the slot again and see what happens.
03-13-2014 11:03 AM
