Page 1 of 16 1 2 3 11 ... LastLast
Results 1 to 10 of 157
    ROG Guru: White Belt Array
    Mar 2014
    103
    i7 3820 overclocking Help
    Ok so I have an i73820 non K/X version of it so I know its locked for overclocking but after digging iv read these a way to but as iv tried I can get a stable OC the cpu I have now is the i73820 3.6 when I originally had it in my alienware comps old mobo it was clocked at 4.2 from the factory since then I have bought a different mobo brand for my comp for more reliability and want to get the cpu back to a stable 4.2 or better with low temps and im at a loss pls help I would really love this thing running like before
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    Hi JP
    The 3820 can OC two ways....you can just increase multiplier up to 43 so 42x100 will give you 4,2GHz or you can change the base clock by using a "strap" of 125....so instead of the multiplier being multiplied by 100 it is multiplied by 125...this is usually for higher overclocks.
    If you are happy with 4,2 or 4,3 it should be as simple as setting multiplier to 42...43...
    http://rog.asus.com/forum/showthread...untry=&status=
    Mar 2014
    103
    Hey Arne
    thanks for the reply ok gotcha so lets say I wanted to go a bit higher with the strap method what should I do to achieve that I'm not sure if my ram can handle it or not thought I would ask before frying it. :P
    Apr 2012
    481
    13,400
    You won't fry it...no worries there...it might not boot but then clear CMOS and start again...
    Mar 2014
    103
    Ok so I tried doing a 125 with 36 as multi and it gave me 4.2 but it's around 74c on high with prime
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    72C at max load (prime) isn't so bad… you won't likely use any applications which would stress that CPU so much… - but I would not raise the Vcore more than you have it now…
    If that speed (4.2) is enough for you, you could try to lower the Vcore notch by notch until it won't boot and/or won't pass your prime… maybe you could save some more in temps...
  7. #7
    Apr 2012
    481
    13,400
    You're right to keep an eye on temps of course. 75 or 80 is a good ceiling. One thing...if you overclock with 125 strap you can't take advantage of speedstep...if you use 100 blck you can so if you go for 4.2 4.3 I would stay at normal strap and bclk. Speedstep lowers clocks and voltage when the processor is idle...a good thing... Try some manual voltages....reducing bit by bit...auto voltage often uses more than you need...if you find a stable manual voltage we can find a good ofset voltage and have lower vcore and speedstep at the same time...
  8. #8
    Mar 2014
    103
    Ok so I'm going to load an image of what iv got goings right now let me know what u think I can make better I guess the offset you mentioned
    Also how low can I go on the cpu vcore im at 1.230v for about 30 mins now no crashes
  9. #9
    Mar 2012
    199
    8,358
    Temps are looking fine!
    One comment though... be careful with AiSuite installed and any other application (Core Temp in this case) which is reading the same sensors... - it may cause crashes later on... but as of now, it seems good...
    Try to use the system for whatever you have built it (your regular applications) and see where the temps will go, and also if the system is stable enough too...
  10. #10
    Mar 2014
    103
    Quote Originally Posted by Zka17 View Post
    what do you mean my regular aplications
