Results 1 to 6 of 6
09-29-2011 11:47 AM #1rolfernGuest
Crosshair V Formula - Wake On LAN
Hi
I have been searching about how to enable WOL for my new Crosshair V Formula in BIOS, but i am not realy sure if i understand what i am supposed to enable.
If anyone could tell me how or maybe even show it with pictures from BIOS?
It would help me a lot, thanks in advance!
Sry for my English.
- Rolfern
06-02-2013 10:20 PM #2
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 2
http://www.youtube.com/watch?v=pDjjMO3az84
Watch this. I had same problem like you. Have the "ASUS Crosshair V Formula/ThunderBolt" and there is no ****ing simple information about the WOL for Crosshair V Formula. But the WOL is a Windows function I guess. You can Enable it on your BIOS it´s in the "Advanced ---> APM" menue the "ErP Rady" should be on "Disabled" then your Motherboard is ready for WOL. The rest is Windows configurationHope you want to start your system from a Smartphone and not from another system. Because I was looking for Smartphone WOL ^^ This tutorial worked well for me. Now I can Turn on the PC even when I´m travelling by using Team Viewer. Full Control of the PC everywhere
Good Luck
06-03-2013 08:31 AM #3
Have repped you X-EQt-R solid reply.
09-20-2015 04:10 AM #4
D.V.D PC Specs Laptop (Model) Asus G752VS-BA177T Motherboard Asus Crosshair 5 Formula Z Processor AMD FX-8350(Vishera) Memory (part number) Kingston HyperX KHX2133C11D3/8GX Graphics Card #1 Asus GTX 980 Matrix Platinum Sound Card on board Monitor Sony TV KDL-32w706b Storage #1 SSD Kingston HyperX 3K 240Gb Storage #2 WD 500Gb + WD 3x1TB(fzex) CPU Cooler Thermaltake NIC-C4 Case Thermaltake core v51 Power Supply Corsair AX760i Keyboard SteelSeries APEX Mouse A4Tech Bloody Gun3 V7 Mouse Pad A4Tech Headset/Speakers Asus ORION / Sony MHC-RG290 OS Windows 8.1 Pro Network Router TL-WDR3600 Accessory #1 7 x 120 fans
- Join Date
- May 2013
- Reputation
- 10
- Posts
- 94
OR this link...this helped me a lot since i didn't know what to enable/disable in bios...
Last edited by D.V.D; 09-20-2015 at 04:11 AM. Reason: Forgot to enter the link lol
MB = Asus Crosshair V Formula-Z info
CPU = AMD Fx-8350 Bios 2101info
RAM = Kingston HyperX Beast 16GB (2x8Gb) 2133 KHX21C11T3K2/16X info
GPU = Asus GTX 980 Matrix Platinum info
SSD = Kingston HyperX 3K 240Gb
HDD = WD 500Gb +WD 3x1TB(fzex)
PSU = Corsair AX760i info
CPU Cooler = Thermaltake Nic C4
Display = Sony KDL-32w706b info
Mouse = A4Tech Bloody Gun3 V7
Keyboard = SteelSeries APEX info
10-11-2015 01:18 PM #5
- Join Date
- Aug 2013
- Reputation
- 10
- Posts
- 2
This didn't work for me, I just updated to the latest BIOS too.
If I have my PC in sleep mode, WOL works. If I shut it down, it does not work. The activity lights on the NIC don't flash anymore when the PC is fully shut off. Is this normal or shouldn't there be a way for this to wake it up from a shutdown state?
06-03-2016 01:45 AM #6
- Join Date
- Nov 2015
- Reputation
- 10
- Posts
- 2
lmao; this post makes me laugh.. WOL does not work when the computer is powered off... the computer is not running, the MO is shut off, there is no way it can wake it.
Sleep Mode puts the computer in a low power mode, MoBo is still powered and is possible to WOL.
WOL = WAKE on LAN... To wake something must be sleeping
WOL does not = POWER on Lan.
Similar Threads
Wake On Lan - Maximus IV Extreme
By grey_hammer in forum Other Series MotherboardsReplies: 4Last Post: 12-22-2011, 04:21 PM -
Abnormal Reading from Wake-Up?
By chrsplmr in forum Other Series MotherboardsReplies: 2Last Post: 08-02-2011, 05:40 PM -
Gene-Z Won't Wake From Sleep
By slider162 in forum Other Series MotherboardsReplies: 1Last Post: 07-04-2011, 11:46 AM -
wake on lan on G73
By jeprira in forum ROG Gaming NotebooksReplies: 4Last Post: 09-16-2010, 07:15 PM
