Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
  1. #21
    ROG Member Array
    Feb 2014
    18
    Why sell a card that supports tri or quad sli but you can't physically do it? Pretty lame if you ask me.
  2. #22
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    Because most people who does 3- or 4-way SLI goes with water-cooling - and water-blocks are thinner than the original heatsinks...
  3. #23
    ROG Member Array
    May 2014
    12
    I bought two of those Asus GTX 780 Direct CU II and sent them back... **** them and **** their stupid design! I'm not buying Asus graphics cards until they learn how to design graphics cards that fulfill their specs. Thanks for the very helpful thread.
    I'm getting EVGA GTX 780. Cheers!
  4. #24
    ROG Member Array
    Sep 2013
    Can we get an update on this? I'm thinking about doing 2 way SLI with these cards.
    Does removing the backplate void the warranty?
    Also, to the original poster, you said you had it working with slots 1, and 2. Do the fans work properly (especially on the card in the first slot)?
  5. #25
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    Quote Originally Posted by Sharpnd152 View Post
    what MOBO to you have?
  6. #26
    ROG Member Array
    Sep 2013
    Quote Originally Posted by kkn View Post
    Maximus VI Formula
    My (current) setup:
    The card at the bottom is a USB 3.0 PCI card, which would be lowered to the very last PCI slot.
  7. #27
    Aug 2011
    243
    6,112
    you will have a opening between the GPU's there when you add the second dual slot card.
    its when you add a 3slot card you will have problem.
    http://cdn.overclock.net/3/35/500x10..._DSC02565.jpeg
    thats 2 dual slot cards.
  8. #28
    ROG Member Array
    Sep 2013
    Awesome, thank you!
  9. #29
    ROG Member Array
    Sep 2013
    edited
  10. #30
    ROG Guru: White Belt Array 1stcowgirl's Avatar
    Sep 2012
    83
    Quote Originally Posted by SuperNeoSpide View Post
    Thank you,
    SNS
    off topic,
    would you mind sharing you VRM readings on the cards? (some of us gets very high temps)
    ºi7-4790k, ºZ97-A, º4x4GB Ripjaws X 1600mhz, ºASUS GTX 780Ti OC [DC2OC] ºCorsair GS700, ºCM 690 IIIº LG E2241T ºWin 7 Ulti' SP1 x64
Tags for this Thread
