Yeah the hardware used is as follows. It is also shown in the video.
Case: Custom built desk mod.
CPU: Intel Ivy Bridge Core i7-3770K @ 4.5 Ghz (still tinkering with the overclock)
Motherboard: ASUS Maximus V Formula Z77 ATX board
Memory: 16 GB of DDR3 from GSkill
Hard Drive: RAID 0 array using 2x 128 GB OCZ Vertex 4 solid state drives for the operating system. I also have 2 Western Digital 500 GB black drives in a RAID 1 array for data storage and backup.
GPU: EVGA Nvidia GeForce 670 (x2) in SLI
Power Supply: OCZ Fatality 1 Series 1000 Watt PSU with red LEDs
Optical Drive: LG DVD/CD Burner Combo and a LG BluRay Burner drive
Operating System: Windows 7 Pro
Monitors: ASUS 23" 120Hz 3D Monitor (x3)
Cooling System: EK D5 140mm reservoir with D5 vario pump, EK acrylic CPU water block, EK acrylic GPU water blocks, EK acrylic SLI bridge, 2 240mm EK radiators, and EK blood red coolant. I have 3 140mm fans by Aerocool up front as intake fans and 4 120mm fans on the radiators as outlet fans.
Case: Custom built desk mod. * CPU: Intel Haswell Core i7-4790K * Motherboard: ASUS Maximus VII Formula Z97 * Memory: 16 GB of DDR3 from GSkill * Hard Drive: RAID 0 array using 2x 250 GB Samsung Evo SSDs for the operating system. * GPU: EVGA Nvidia GeForce 670 (x2) in SLI * Power Supply: OCZ Fatality 1 Series 1000 Watt PSU * Optical Drive: LG BluRay Burner * Operating System: Windows 8.1 Pro * Monitors: ASUS 23" 120Hz 3D Monitor (x3) * Cooling System: Custom water cooling loop.
