Page 1 of 17 1 2 3 11 ... LastLast
Results 1 to 10 of 166
    ROG Guru: Yellow Belt Array siliconart's Avatar
    Aug 2013
    23
    136
    Smile || Help with OC 4470k + Hero VI + H100i ||
    Hey Nate152,
    From your posts I have read, you seem to really know what you are doing.
    I was wondering if you could help me OC my 4770k?
    System Specs-
    CPU- Intel Core i7 4770K
    Motherboard- Asus MAXIMUS VI HERO
    RAM- Gskill TridentX 16GB (2x8) DDR3 2400Mhz
    GFX Card- Asus Geforce GTX780 DirectCU II OC 3G
    SSD- Samsung 840 PRO SERIES 256GB
    HDD- WD 2TB Caviar Black 7200rpm
    CPU Cooler- Corsair Hydro Series H100i (Fans upgraded to: Air Series SP120 HP)
    PSU- Corsair AX860 Platinum Power Supply
    All Fans controlled by AiSuite
    My time zone is +10GMT
    Regards,
    siliconart
    ROG Enthusiast Array r0wnin's Avatar
    Mar 2014
    31
    Start at 4.4 with a 4.2 cache and a 1.25 vcore
    c-states & Intel speedstep disabled
    If you get WHEA bsod's you need to either up your vcore or drop your multi.
    [Asus HERO - i7 4770k @4.3 - 32gb G.Skill Ares @2400 via XMP - Samsung 840 SSD - 660GTX in SLi]
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Hello siliconart, You have a good cpu cooler and should be able to hit 4.4-4.5 GHz with the H100i. Have you downloaded real temp 3.70, cpu-z and prime95 or realbench? If so go into the bios extreme tweaker tab and set the AI Overclock tuner to manual, sync all cores and set the cpu core ratio to 42 and set the cpu core voltage to 1.25v F10 and Enter. Open up cpu-z, real temp and prime95 or realbench and run a stress test. Monitor the maximum temp in real temp and core voltage in cpu-z. Temperature controls how far you will be able to overclock. If the temp goes over 90c when running the stress test stop the test immediately. Report your temps please.
    Aug 2013
    23
    136
    Yes, downloaded all those apps )
    Which do you prefer I use Prime95 or Realbench?
    4.4-4.5 sounds nice, should I be dropping the Ram down from 2400mhz to something average?
    thanks
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Use realbench and you can let your ram at 2400MHz.
    Aug 2013
    23
    136
    ok, should I be resetting all the values on the Mobo to defaults?
    Also in the RealTemp folder I seem to have 3 options-
    1. RealTemp
    2. RealTempGT
    3. i7TurboGT
    Which should I be running?
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    yes you can hit F5 to set defaults before doing the steps and you can use real temp.
  8. #8
    Aug 2013
    23
    136
    Ok here are the results for-
    42 @ 1.25v
Name:	4.2 @ 1.25v.png
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Ok your cpu is not running at 4.2Ghz. Open real temp ,click settings and make sure disable turbo is unchecked cpu-z shows your cpu at 800MHz.
  10. #10
    Aug 2013
    23
    136
    Yes disable turbo was and is unchecked
    cpu-z did show it go upto 4.200 when running RealBench
    Should I be Quitting AiSuite from the system tray? I don't have it up on screen or anything, as it controls the fans, or will the Mobo do that anyway?
