Need expert advice about *** rog vga cards ***
Just1ove
HELLO EVERYONE..
i have build a pc but cant decide which VGA card should i buy ?
will u guys pls help me out..i realy ll apreciate the help ... thx
AMD FX X8 8350 Soket AM3+ 4GHz 16MB Cache 32nm
G.Skill Trident X 16GB (2x8GB) DDR3 2400MHz CL10 1,65V
SEAGATE 3.5" 1TB Barracuda Sata 3.0 64MB Cache 7200Rpm Harddisk
ASUS CROSSHAIR V FORMULA-Z
CORSAIR Hydro Series H110 280mm Extreme Performance Liquid CPU Cooler
CORSAIR 240GB Force GS Series Sata 3.0 SSD(Read 555MB / 525MB Write)
CORSAIR Obsidian Series® 750D Full Tower ATX Case
CORSAIR RM750 Watt 80 PLUS Gold - Fully Modular
1 *** ASUS ROG MARS760-4GD5
http://www.asus.com/us/Graphics_Cards/ROG_MARS7604GD5/
2 *** ASUS ROG POSEIDON-GTX780-P-3GD5
http://www.asus.com/us/Graphics_Cards/ROG_POSEIDONGTX780P3GD5/
3 *** MATRIX-R9280X-P-3GD5
http://www.asus.com/us/Graphics_Cards/MATRIXR9280XP3GD5/
ps: i am also open to suggestions..
thx a lot for ur help...
11 REPLIES 11
PowerOver9K
That Crosshair might not run with that RAM!!! It's too fast for AMD I believe but I'll let someone else Chime in. I only GPU for Team Red...
I'll say that for one, Get the Mars Card...
Mobo: Rampage IV BE | CPU: i7-4930@4.5ghz Hexacore | RAM: 32GB Corsair V-Pro | GPU: 4xR9 290X Quadfire | PSU: eVGA P2 SuperNOVA 1000W\G2 850W | Chassis: NZXT Phantom 820 | Cooling: XSPC Raystorm CPU Block\4xEK 290X Block\2x Laing D5\XSPC Dual Bay Res\Phobya G-Changer 1080 External Rad\Alphacool 140UT60\XSPC AX360 | Fan Con: Lamptron CW611 | Tube: Primochill Adv. LRT Bloodshed Red | 3xCrossover 27" 2560x1440 Monitors | Build Log of Insanity
Myk_SilentShado
Level 15
Hey there, you've got a great looking build hardware wise 🙂 your RAM should work no problems. As you've elected to buy a kit with 2 sticks of RAM, you should be able to easily hit 2400MHz. The 8350's do have a pretty good IMC, if you're into Overclocking, you may even get higher on the Memory, but that depends on just how good the CPU's IMC is 🙂
If you're looking for a ROG card, you could also get a Matrix 290X rather than the 280X version. How many cards are you planning on running? just one, your 750W PSU should be fine, but, if you plan on going more than one card, you're gonna need more juice 🙂
i am loking to buy ROG card ( got window case,i like the Look at the engine 😄 ) and yes i am planing to use 1 card only ( thats why i got 750w psu ) ..but dunno which ROG card i should get for this Rig..i have heard about some gaming problems with SLI systems that run me away from Mars760x2 and i am not %100 sure about poseidon ..
these are the reasons i requested some expert advice..
and ş would lıke to thank u all for reply...
Arne_Saknussemm
Level 40
For a single card I would go with the Poseidon 780, if you are going to watercool it of course; If not I would not buy that card but get a Matrix 290X or 780Ti or regular 780.
The 760 Mars is a good card if you want two GPUs but don't have much room. Buying two normal 760s and running SLI will give better performance and is cheaper....but I would get an 850w PSU for SLI...
PowerOver9K
760 Mars card beats 780 Poseidon in most benchmarks including Bioshock, Last Light and Battlefield 4. Google it.
kkn
Level 14
780 if you can afford it.
770 and down is boosted 6XX series cards
Antronman
You can't find the Matrix 280x anymore, and the new matrixes haven't gone on the market yet.
Posideon 780.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
Myk_SilentShado
Level 15
The new Matrixes must be on the market, since a couple of Members own them.
X-ROG
Level 15
Depends on your budget and performance needs.
In terms of performance (fastest to 'slowest'):
MARS 760
Matrix 780 Ti/R9 290X
Poseidon 780
Matrix R9 280X
