Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    New ROGer Array
    Nov 2014
    1
    Hi. This thread isn't solved yet right (or is it)? Please help me too, us. I'm having this same, exact problem with my Asus X200CA. Except that I have a non-removable laptop battery. Please, I need this laptop for studying.
    Edit: Sorry for replying on a month old thread. This is the only one I found which is exactly as my problem.
  2. #12
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    Quote Originally Posted by benjo View Post
    benjo, actually this thread was started 7 months ago
    These forums are for ROG laptops. I did a search on your model number, and only your post showed up.
    You say the battery isn't removable, but I did a google search and found a number of places offering replacement batteries
    https://www.google.com/search?q=asus...x-a&channel=sb
    If the laptop is still under warranty, you can file a Technical Inquiry to Asus telling them of the problem, and ask for an RMA to fix the problem. It might not be the battery, it might be the charging circuit and so getting a replacement battery wouldn't fix that problem.
    https://vip.asus.com <== create a login, register your laptop, and file the Technical Inquiry asking for RMA to fix the laptop/battery.
    IDK if Asus has a forum for your laptop anywhere else, but the only other place I know of, I use it for motherboard support, doesn't have a laptop section.
    http://vip.asus.com/forum/default.aspx?SLanguage=en-us
    You might ask Asus in your Technical Inquiry if they have a support forum for your laptop
    Good luck!
  3. #13
    New ROGer Array
    Apr 2015
    1
    Works for me!
    Quote Originally Posted by hmscott View Post
    Chris, this method worked for me, it happened on my JW, and after doing this, the problem didn't come back.
    Go into the Device Manager, Expand the Batteries group, Right click on the Microsoft ACPI-Compliant...Method Battery, select uninstall and after it uninstalls, click on the Action tab, select scan for Hardware Changes.
    Then reboot. Let us know if that fixes it
    This worked for me. I found that if I uninstalled then scanned for hardware changes it started the charging cycle but stopped after less than a minute and remained on 0% available. The trick was to uninstall, scan for hardware then shut the lid as soon as the charging cycle started, putting the laptop top sleep. This was enough to establish the charging cycle and now I have a fully charged battery again. Brilliant! This is my 2nd replacement battery and I could have saved myself the expense and inconvenience had I known about this technique. Thank you.
  4. #14
    New ROGer Array
    Mar 2015
    2
    Old thread but i thought I'd answer
    If the uninstall/reinstall of the battery drivers does not work, you need a new battery...Other solutions DON'T work (there are a couple of them online)...
  5. #15
    ROG Junior Member Array
    Feb 2013
    1
    Quote Originally Posted by Flotterz View Post
    Hi there. I did that part uninstall the battery from device manager then after i uninstall it my laptop was turned off. After the reboot, the battery status stayed at 0% and it says "charging" and the battery that ive uninstalled was restored. Please help
Tags for this Thread
