I need a wireless a/c daul band for my S56CA-DH51..
Arjai
Budget: under $100
Main uses of intended build: I surf and download Movies at a coffee shop with a barely used 5g router
Parts required: A card that WILL work in this, don't want a USB.
Previous build information (list details of parts): Currently is the OEM Atheros N card
Monitor resolution: Doesn't really matter, does it?
Storage requirements: Storage is fine, eyeballing an SSD for it after the wifi card
Extra information about desired system: ASUS says they cannot give me any recommendations.:(
Perhaps, a few of you may have a suggested wifi adapter that will work?
Thanks!
I was referred here from TPU, two years + on their Crunching team.
I had a hell of a tough time updating my brother's ACER a little over a year ago. I am hoping that I can avoid that mess by reaching out to the folks here. Any help is greatly appreciated.
I was recommended a Intel® Dual Band Wireless-AC 7260, but i am unsure this is white-listed, black-listed or what? If it will definitely work I will pull the plug.
kkn
Level 14
try and post in the notebook section, you will get faster responce there since thats where the users whit laptops hang out.
OK, Thanks!!
