Results 1 to 10 of 10
    New ROGer Array
    Apr 2014
    2
    Hero PWM fan control; do the chassis connectors have individual channels?
    I am about to order a new PC. I will have three groups of chassis fans and would like to control each group separately.
    Are the CH1, CH2, and CH3 PWM connectors on individual PWM channels, so they can be directed to spin at different speeds?
    Alternatively, do the CPU and OPT connectors provide sufficient power for chassis fans? I won't need a CPU fan. This will be a liquid-cooled setup.
    ROG Guru: Orange Belt Array geneo PC Specs
    geneo PC Specs
    MotherboardMaximus X Code
    ProcessorIntel 8086K @ 5.1Ghz
    Memory (part number)32 GB (2x16) G.Skill TridentZ RGB 3200 MHz CL14 @ 3600 15-16-37
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    MonitorEIZO Coloredge CG2730 and Dell
    Storage #1Samsung 512 GB 960 Pro
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black HDD
    CPU CoolerNoctua NH-D15 Chromax
    CaseFractal Design R4 w/ tempered glass
    Power Supply750W Seasonic Prime Ultra Titanium
    Keyboard CM Quickfire Rapid TKL
    Mouse Logitech G305
    Headset Bose
    Headset/Speakers Vanatoo T1, ML Dynamo 300
    OS Windows 10 Pro X64
    geneo's Avatar
    Feb 2014
    27
    370
    Only the CPU and CPU OPT are PWM, and they are controlled together.
    The chassis fans 1-3 are voltage controlled, but can be controlled separately.
    The CPU and CPU opt are 1A. If you have low power fans like Noctua, you can run more than one off o them.
    ROG Guru: White Belt Array
    Oct 2013
    87
    CHA1-3 have 4 pins and are easily controlled using Fan Xpert in AISuite3. Wouldn't that make them PWM controllable? Furthermore they ask that you set the q-something in bios if you are using a 3pin fan so it can adjust them as needed.
    i7-4770k @4.2 | EVGA 780ti | Maximus VI Hero | Seasonic 1000W Platinum | Seidon 120v AIO
    Trident X 16GB 2400 | Samsung EVO 500GB | Seagate Barracuda 2TB | CM 690 III
    Logitech G400 Mouse | G710 Keyboard | Razor gaming headset
    ROG Swift pg278q G-Sync Monitor
    ROG Guru: Blue Belt Array jab383 PC Specs
    jab383 PC Specs
    Motherboard24/7 rig : Maximus VI Extreme
    Processori7 4790K
    Memory (part number)16GB Mushkin Redline 2400 10-12-12-28 + 16GB Corsair Vengeance 2400 10-12-12-31
    Graphics Card #1AMD Firepro W5000
    Sound CardM6E Supreme FX
    MonitorDell U2413
    Storage #1Kingston SH103S3240G SSD
    Storage #2Seagate ST1000DM003 1TB
    CPU CoolerCustom water loop, Delidded, Liquid Metal TIM
    CaseCoolerMaster HAF XM
    Power SupplyCorsair HX-750
    Keyboard Logitech G710+
    Mouse Logitech M705
    OS Windows 7 64 Pro
    jab383's Avatar
    Feb 2014
    107
    855
    The chassis fan headers are controlled by seperate profiles in either BIOS or AISuite, but all three profiles are based on the CPU temperature sensor. In that they all depend on CPU temperature, they are not "independent channels." The M6E and M6F have OPT_FAN headers in addition to the CPU and CHA headers. For each OPT_FAN header, there is an OPT_TEMP header. When a temperature sensor is plugged into the OPT_TEMP header, that temperature can be used to control the corresponding OPT_FAN.
    Each fan header can drive up to 1 amp. Any fan, or combination of fans on a splitter cable, that totals less than that can be connected. A common approach is to use the sort of splitter cable that draws power from a PSU molex and connects only the PWM and tachometer leads to the MB header. I have pump and radiator fans on that sort of connection now.
    In your liquid cooled setup, plan on connecting something to the CPU_FAN header. That's to prevent BIOS from hanging in an alarm condition over the lack of CPU cooling. Radiator fan PWM and tach are good choices. I've put the pump tachometer on that header when fans were all controlled elsewhere.
    Jeff
    New ROGer Array
    Apr 2014
    2
    Thanks for the detailed reply. I will have just one water loop (with CPU and GPU in series) so the CPU thermal sensor is a reasonable input to the fan speed for all channels. The available current information is also helpful; I wished that information was in the spec sheet or instruction manual for the motherboard.
    I am new to water cooling and don't know if the pump I've ordered has a tacho output or PWM control feature. My hope is that it won't make much noise at full speed.
    geneo PC Specs
    Mouse Logitech G305
    Headset Bose
    geneo's Avatar
    Feb 2014
    27
    370
    Quote Originally Posted by Veracis View Post
    No, the 4th pin that would be for pwm control Is held st 5V. They are voltage controlled, not pwm.
    They are controlled by the cpu temp, but the temp vs rpm curve can be different for each chassis fan and the cpu fan. But the cpu opt fan uses the curve of the cpu fan.
  7. #7
    ROG Guru: White Belt Array Abula PC Specs
    Abula PC Specs
    Laptop (Model)MSI GT73VR Titan-017
    MotherboardASUS ROG Maximus XI GENE
    ProcessorIntel i7 8086K
    Memory (part number)Corsair Vengeance LPX 16GB DDR4 (CMK16GX4M2B3200C16W)
    Graphics Card #1MSI RTX 2080 Ti DUKE 11G OC
    Sound CardOmega eClaro
    MonitorDell S2417DG
    Storage #1ADATA XPG SX8200 960GB
    CPU CoolerScythe Mugen5 RevB
    CaseSilverStone SST-LD01B
    Power SupplySeasonic Prime Titanium SSR-650TR
    Keyboard Logitech G613
    Mouse Logitech G603
    Headset Philips Fidelio X2 + Vmoda Boompro
    Mouse Pad Artisan ZERO XSOFT S
    Headset/Speakers JBL S26
    OS Windows 10 Home
    Network RouterUbiquiti Edgerouter X
    Abula's Avatar
    Jul 2011
    102
    Both Geneo and jab383 are correct.
    Asus and most manufacturers, only have one true PWM fan header, CHA_FAN (CPU_OPT is only a mirror none controllable, just a mirror of the CPU_FAN). The rest of headers CHA_FAN 1,2,3 even though they are 4pin physically, they are are voltage controlled or what some called fake 4pin.
    So just chose careful the fans for each header, all will be binded to the CPU temperature, so really dont matter which you chose, you can controlled them individually, but its important that you dont place PWM fans on CHA_FAN headers, in some cases, they are unstable, to the point even with the FanXpert2 tunning, the lowest voltage is not stablish correctly and in some cases (depending on the fans), they stop.
    First check if your pump is PWM or not, if it is use the CPU_FAN header for it. For the rad and case fans, my suggestion is go with Scythe Gentle Typhoons AP15, Asus motherboards with FanXpert2 can take them extremly low or ramp it them up to their max rpms, so you have a very wide range of operation. I leave you a run on GT AP15 on my GENE,
Name:	Scythe Gentle Typhoon D1225C1285AP-15 1850rpm FanXpert2 on 3pin.png
    Now if you want to go PWM fans, then you have an issue if you pump is PWM, as asus motherboards only have 1 true pwm fan header (even though you do have a mirror on the CPU_OPT), the problem is that even if you use a PWM splitter, the fans and pump will be ran the way the main header will be, and you wont be able to control them seperated, if you wish to go with pwm fanns then go with a none pwm pump, thats if you wish to control them individually.
  8. #8
    New ROGer Array
    May 2014
    1
    really frustrated over the fan and noise in my new setup.
    I have the M IV Hero, and cooler for CPU is coolermaster nepton 140xl, it sais the fans are PWM.
    I have connected the jetfans to chassis 2+3.
    In the fancontroller they either are at 0 RPM or jumps to 60% which is like 1600RPM. I cant take them lower in fanexpert 2, its blocked. The range of the fans is 800-2000+ RPM.
    So now its like no sound, then a vacum cleaner sound, then no sound....
    How can I overide the fans to run at like 800 RPM.
    Or should I just change them.
    BTW CPU fan sais it runs at 6000RPM, but that is not audiable.
    I also have a Fractal design case, is it better to connect to the fan controller on the case..
    As it is now it is absolutly not possible to game with this crazy fan changes..
  9. #9
    ROG Guru: White Belt Array WCPredator PC Specs
    WCPredator PC Specs
    MotherboardMaximus Vii Hero
    ProcessorI7 4790k
    Memory (part number)F3-14900CL8D
    Graphics Card #1Strix 1070ti
    Sound Cardo.b. SupremeFX
    MonitorG24C
    Storage #1Sandisk Extreme Pro 480
    Storage #2Toshiba 3TB
    CPU CoolerNoctua D15
    CaseCM HAF 932
    Power Supplyevga 650 g3
    Keyboard G110
    Mouse G502
    Headset HyperX Cloud II
    Mouse Pad Taito under a Qck lol, it works
    Headset/Speakers HyperX cloud II / GNT 5000
    OS 10/64
    Network RouterMikrotik HexS
    Dec 2014
    83
    Quote Originally Posted by jab383 View Post
    Jeff
    Hi Jeff, are you 100% sure that all of chassis fan headers can safely push 1Amp each on a Hero VII? I have a 140mm case fan that pulls 0.14A like I assume they are designed for - but I also have three 230mm case fans that pull 0.40A each. I've read about chassis fans connections bricking ASUS boards, and I don't want to push it. Also have a noctua D15 on both cpu fan headers if that adds to the stress, as I would be using every single fan header.
  10. #10
    jab383 PC Specs
    Processori7 4790K
    MonitorDell U2413
    Mouse Logitech M705
    OS Windows 7 64 Pro
    jab383's Avatar
    Feb 2014
    107
    855
    That's what ASUS says. I've connected two 140mm to one header plus three 200mm each to their own header. Each controlled header would have its own MOSFET -- that's what sets the limit -- so the stresses are supposed to be independent. They do depend on having the 8-pin PSU connection.
    Jeff
