Haswell IMC's
Retired
Not applicable
One thing has struck me..
is the difference so fokkin huge when in comes to the IMC, and the mem speed from chip to chip..
I have friends running the 4770k + 2800mhz just fine
This 4670K specimen is maxed out at 1600mhz (4gb) 6.6.4
And at 4800mhz only 1333mhz (4gb) 5.5.4
If i bump up the ram speed and voltages and loosed up the timings much ( 2000mhz 7.7.7 or 1866mhz 7.8.7), i get artifacts/freeze and crash, and if i tighten the mem really hard, i get even lower speeds as a result
Its borderline Intel spec..
at stock cpu clock its 1600mhz-1700mhz mem speed max (loose timings)
Please share some light over this..
/ Gryphon Z87/4670K tested with 5 different kits (same outcome)
45 REPLIES 45
Retired
Not applicable
i am getting some new chips.. but still.. is it this bad
this is max stable 24/7 dram frequency at default 4500mhz ........... ITS POOR
Arne_Saknussemm
Level 40
I heard the IMC on Haswell was not silicone but a wafer thin slice from a cream-cheese bagel! Might explain it...
Retired
Not applicable
yes, would certainly do
No space what so ever for MEM overclocking
Arne_Saknussemm
Level 40
Actually, what's wrong with that?...I just looked at my crib sheet and 1600 Cas 6 is 7.5ns like all the best timings....2400 C9 2666C10 2933 C11 (will we ever see it?)
Retired
Not applicable
i am stuck at 1600mhz, and when i start to push it, the dram frequency drops even lower.
It will work for 24/7 duty, but not for overclocking
Retired
Not applicable
2400mhz 7.7.7 is better
2400mhz 6.7.5
Arne_Saknussemm
Level 40
yeah...I guess mainstream is mainstream...and the bagel theory holds up....see what the next lot of soldered chips are like....
Retired
Not applicable
i am getting 2 more specimens of the Haswell K they cant be this poor? or can they
Retired
Not applicable
Please can some members post some cpu-z mem speed with the haswell?
I dont want to go back to Ivy, but if it is really bad, i will do so.. i wont buy 10 haswell chips, just to find a overclocker
