Results 1 to 2 of 2
    ROG Member Array
    Sep 2013
    7
    do you have a problem?
    I performed the test with the realbench and my score is what you place in the picture, I saw scores much higher do you think it is a configuration problem?
    Helium Chilled Array _ PC Specs
    _ PC Specs
    Laptop (Model)G46VW
    MotherboardRampage IV Gene
    ProcessorIntel Core i7-3930K
    Memory (part number)Corsair Dominator Platinum 32GB (CMD32GX3M4A2133C9)
    Graphics Card #1ROG Matrix GTX 780 Ti
    Sound CardROG SupremeFX III
    MonitorASUS VG248QE with GSync mod
    Storage #1Plextor PX-M2 SSD 120GB
    Storage #2G.Skill Phoenix Blade 480GB PCIe SSD
    CPU CoolerCooler Master Seidon 240M
    CaseCooler Master HAF-X
    Power SupplySeasonic X-750
    Keyboard Corsair K90
    Mouse ROG Gladius
    Headset ROG Orion
    OS Windows 8.1 Update 1
    Network RouterASUS RT-AC66U
    _'s Avatar
    Dec 2011
    119
    5,750
    Compare other G750JX scores and see where you are lacking. Without a very detailed look it seems to me your GIMP and OpenCL scores are a little low.
    Check your OpenCL drivers are installed correctly.
    Switch to high-performance mode
    Try memory with tighter timings (you'll have to buy new though as our G-series BIOS does not offer memory timing adjustments, so not really worth it just for a faster number)
    Maybe search for some software that can tweak the base clock a few notches to 101/102MHz. We don't provide this for notebooks sorry.
