Been a blast putting the Liquid Cooling Loop together, I purchased this 900D month agowith full intentions of going this route!
Absolutely tired of setting up Fan Profiles for my GPU's only to constantly see obscene Temps and loud wailing fans.
So its done:
Didnt go to crazy -
2 x XSPC EX 360 Rads - both push / pull: only require 50% Fan Speed, so very quiet.
Top Rad Exhaust / Bottom Rad Intake
Photon 170 D5 Vario Pump / Res Combo
EK Supremacy CPU Block
2 x EK Full Blocks w Backplates on the 780Ti's
Fesser UV Blue Tubing 3/8" ID 5/8" OD
Crap load of Bitspower black fittings
Using clear Fesser 1 Coolant
I'm also running 3 x 120mm Silverstone Penetrators in the Front of the Case (Intakes) and a Gelid Wing 140mm top back Intake - really want to stick to Positive Pressure!!
All Fans running off of a Lamptron FC 9 - 4 Channel 200W Fan Controller (50W per Channel)
780Ti's - OC'd Core +160 Mhz / Memory +275 Mhz - Boosts to 1270 Mhz
Looping Heaven 4.0 for 30 min:
Max GPU Temps: GPU#1 47c / GPU#2 45c
CPU: 4.8 Ghz Offset +.075v Max vcore under full load 1.385v
Max Temp on one of the 6 Cores 72c
Ambient room temp: 23c
Anyhow, in the Fall when I do my first liquid change I'm going to install another 240mm Rad, RIVE Mobo XSPC Block and the D5 Vario Bitspower Modding Kit!!!
Cheers and tanks for stopping by:
RJ
