Results 1 to 3 of 3
    New ROGer Array
    Dec 2012
    2
    G75VX touchpad left button does not work properly
    Hey all,
    My Synaptec touchpad does not work properly. Left mouse button is like "always" pressed. Moving the mouse with the touch pad selects text, moves items and so on depending where I am. Do you have any idea what could cause this? I have been using Win 8 and later Win 8.1 without any issues, but 2 days ago this problem started. Running in Safe Mode did not solve it and I have seen it there as well. Normal USB mouse works OK, but using the touch pad is a nightmare at the moment.
    Any ideas?
    10x
    ROG Guru: Brown Belt Array GottiBoi55's Avatar
    Dec 2011
    22
    1,117
    Quote Originally Posted by rossenbg View Post
    Hey all,
    Any ideas?
    10x
    Try a driver reinstall/repair, maybe that will fix your issue.
    I'm pretty sure that will fix issue, if the touchpad is not defective.
    GottiBoi55
    Asus
    G750JZ-DS71 Windows 10 Pro (x64)
    Intel® Core™ i7 4700HQ (2.40GHz)
    Samsung
    24GB Memory DDR3 1600 MHz SDRAM
    SanDisk
    M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
    NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
    Second Monitor: Shar
    p Aquos 32"
    New ROGer Array
    Dec 2012
    2
    Unfortunatelly, deinstalling and instaling the Synaptec driver again did not solve the issue. Left touchpad button is again shown as "pressed", tap on the touchpad is not like "left click", tap-tap is not like double click.
Tags for this Thread
