05-07-2014 08:29 AM - last edited on 03-05-2024 11:09 PM by ROGBot
05-07-2014 11:01 AM
05-07-2014 09:30 PM
05-07-2014 09:51 PM
05-07-2014 10:01 PM
Akul Cora wrote:
Sorry about that, it's JM, not JZ...
Anyhow, GPU activity icon is already in the taskbar and indeed, nvidia does not kick in. Also settings.exe does not exist as such (or I can't find it, but doubt that's the case) but launcher.exe does exist and adding it does not solve the problem. Even tried setting that nvidia is always used for all applications in global settings and that did not solve the problem either.
Any other ideas...?
05-09-2014 06:45 AM
05-09-2014 11:01 AM
Akul Cora wrote:
Thnx for the reply!
I played for a day or two with these when I had the time, and am sorry to say that none of them worked... The one that seemed promising included changes to skyrimprefs.ini, something similiar already helped with almost exactly same problem when running Fallout 3, but sadly not with Skyrim.
Anyhow, if anybody has a solution that would be much apreciated, I will continue googling and hopefully post the fix when I find one.
05-09-2014 11:54 AM
hmscott wrote:
Akul Cora, you might try putting a request out on the support forums for Skyrim, this has to be a common problem with Optimus computers. The "fix" likely changes as new releases come out, so keep looking 🙂
05-09-2014 11:55 AM
