Results 1 to 6 of 6
    bertazzo8
    Guest
    G73SW-3DE SCREEN problem
    hi guys i'm new here and i came to talk about the problem on my g73sw-3de it just don't show any video even from the bios to windows but you can hear the sounds from operational system i have tried on vga and hdmi and no signal was found.
    i hope you can help me
    peace!
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    Are you saying your G73SW-3DE is not displaying any video to a 2nd monitor or an LCD TV? What brand and model? If it is a TV be sure you have selected the proper HDMI or RGB input on your TV.
    In Screen Resolution, is the 2nd Monitor detectected?
    Or are you saying your laptop monitor does not display ANY video?
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Sounds like he has NO video at all.
    If it's new return it, otherwise set up an RMA with asus.
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    bertazzo8
    Guest
    no video even in hdmi and vga i will try the flat cable but to found where i can buy is hard ;(
    bertazzo8
    Guest
    i forgot to say in the post that i bought one new lcd screen and replace and the problem remains
    i wanna know what is RMA i'm glad if someone could tell me
    Sep 2011
    89
    4,437
    RMA = Return Merchandise Authorization Typically, you contact ASUS and describe your problem. They give you an RMA number to authorize the warranty repair work. You include the RMA number or RMA Application in the box shipped to ASUS.
    However, if you just purchased your system, I recommend calling the retailer to see if he will immediately replace it with a new laptop.
Similar Threads
  1. G73SW-A1 screen problem
    By Ramy in forum G Series Gaming Notebooks
    Last Post: 04-28-2015, 06:57 PM
  2. G73SW-A1 Screen goes Blank then idles
    By rurilused in forum G Series Gaming Notebooks
    Last Post: 02-15-2012, 12:39 PM
  3. G73sw screen/artifact issue - Help needed :)
    By kafufle in forum G Series Gaming Notebooks
    Last Post: 09-18-2011, 08:50 AM
  4. Is my G73Sw's screen messed up?
    By Shotus in forum G Series Gaming Notebooks
    Last Post: 06-15-2011, 04:12 AM
  5. G73SW-XA1....blue light below screen not found
    By moudy in forum G Series Gaming Notebooks
    Last Post: 06-06-2011, 04:58 PM
