Replacing anti glare coating on asus monitor - help
ThermalX
Hi! I have a scratch on my Asus PA238Q monitor. I tried to remove it with Novus polish and it helped a bit, but it's still there and now I also have a little patch around the scratch that is noticeably more reflective >.> ya...I may have over done the polishing a bit...
So, I don't think the scratch penetrated beyond the protective coating or I would have seen the effect on the monitor, right?
My idea was to remove it as instructed here:
http://hardforum.com/showthread.php?t=1674033
And replace it with a good protective cover to avoid this:
http://www.overclock.net/t/1230911/removing-the-anti-glare-coating-on-u2711
My question is, is there any specific cover I need to get or is any kind of monitor protective film suitable?
I am a little concerned about having a gloss monitor because of the lighting in my room, but at the same time I am curious to see if the colors will be nicer while maintaining high color accuracy.
I would just like to hear some opinions. I plan to do this only if I feel sure I can do it correctly. So I am reading as much as I can about the procedure and I am interested in hearing people's opinions and helpful advice.
ThermalX
Please, anyone? Anything?
