Results 1 to 5 of 5
    ROG Guru: White Belt Array ali├╝nl├╝ PC Specs
    ali├╝nl├╝ PC Specs
    Laptop (Model)none
    MotherboardRampage IV Black Edition
    Processori7 4930 K
    Memory (part number)CMZ16GX3M2A1600C9
    Graphics Card #1Asus Titan X ( maxwell )
    Graphics Card #2none
    Graphics Card #3none
    Graphics Card #4none
    Sound Cardonboard
    MonitorAsus VG248QE
    Storage #11.Corsair Force GS (240 gB) 2.Corsair Force GS (128 gB) 3.Corsair Force LS SSD (240 gB
    Storage #2Seagate 1tB
    CPU CoolerCooler Master: Seidon 240M
    CaseCooler Master Sniper
    Power Supply1500w silverstone
    Keyboard Logitech G510
    Mouse Logitech G502
    Headset Creative sound blaster Alpha Tactic 3D
    Mouse Pad none
    Headset/Speakers Creative T6300 5+1 Speaker
    OS Windows 10 pro 64 bit
    Network Routernone
    Accessory #1 Logitech HD Webcam C615
    ali├╝nl├╝'s Avatar
    Aug 2013
    110
    Is there a problem???
    hi people! what is TMPIN 2 ?
    And it is 128 C' always 128C'
    is there problem or read incorrect values
    I use CPUID HWMonitor
    crosshair V formula Z
    Thank you for your helps
    ROG AirWays Captain Array TenBlade's Avatar
    Oct 2012
    45
    815
    I┤m not familiar with your mainboard, but it could be a hot North Bridge. And that does sound too hot to be healthy.
    ROG Guru: Green Belt Array Heini PC Specs
    Heini PC Specs
    MotherboardAsus SABERTOOTH Z170 MARK 1
    Processori7-6700K
    Memory (part number)G.SKILL TridentZ (2 x 16GB) F4-3000C14D
    Graphics Card #1Evga 2080Ti XC Ultra
    Sound CardAsus Essence STX II
    MonitorASUS MG279Q
    Storage #1Samsung 950 Pro 512GB
    CPU CoolerNoctua NH-D15
    CaseCooler Master HAF XB EVO
    Power SupplyEVGA SuperNOVA G3 1000W
    Keyboard Ducky Shine 6 (Brown Cherry MX)
    Mouse Secret (Ducky)
    Headset Sennheiser HD 580
    Mouse Pad EVGA TORQ
    Headset/Speakers Logitech Z906
    OS Win10 Pro 64
    Heini's Avatar
    Nov 2013
    50
    600
    Quote Originally Posted by ali├╝nl├╝ View Post
    I don't know what TMPIN2 is but it seems to always be at 128C in HWMonitor on every AMD system I build. I presume it is a misread.
    ROG Guru: Blue Belt Array jab383 PC Specs
    jab383 PC Specs
    Motherboard24/7 rig : Maximus VI Extreme
    Processori7 4790K
    Memory (part number)16GB Mushkin Redline 2400 10-12-12-28 + 16GB Corsair Vengeance 2400 10-12-12-31
    Graphics Card #1AMD Firepro W5000
    Sound CardM6E Supreme FX
    MonitorDell U2413
    Storage #1Kingston SH103S3240G SSD
    Storage #2Seagate ST1000DM003 1TB
    CPU CoolerCustom water loop, Delidded, Liquid Metal TIM
    CaseCoolerMaster HAF XM
    Power SupplyCorsair HX-750
    Keyboard Logitech G710+
    Mouse Logitech M705
    OS Windows 7 64 Pro
    jab383's Avatar
    Feb 2014
    107
    855
    TMPIN is usually the name for an external temperature sensor header. That's what it is on my M6F. Check the manual.
    The reading out of bounds suggests either:
    Nothing is plugged in to the header and the reading is garbage
    The wrong resistance sensor is attached and giving distorted readings
    The attached sensor, the header or the sensor chip on the board has a short circuit, which translates to an extremely high temperature
    If you have nothing attached or just want to be rid of the annoying reading, there is probably a setting in BIOS (M6F has it on the temperature monitor tab.) BIOS can be set to IGNORE that sensor input. I think that will keep OS apps like HWMONITOR from seeing it.
    Jeff
    ali├╝nl├╝ PC Specs
    Laptop (Model)none
    Processori7 4930 K
    Sound Cardonboard
    MonitorAsus VG248QE
    Mouse Logitech G502
    Mouse Pad none
    Network Routernone
    ali├╝nl├╝'s Avatar
    Aug 2013
    110
Name:	Ekran Al?nt?s?.PNG
