Annoying issue with Hero LED strip
Josysclei
So, just bought a brand new Hero and I really enjoyed the red led strip on the left corner. But after I shutdown, the led wont come off! The only way to turn it off is to turn the PSU off. Is there a way around this?
RoGHoliday
UEFI/BIOS setting.
Corsair_Riker
I don't know if it is possible to have it turn off when you shutdown the computer (but leave the PSU on).
You do have the option of permanently turning it off - though - in the BIOS under "Advanced > ROG Effects "
MOTHERBOARD: ASUS Maximus VI Formula (BIOS 0804)
CPU: Intel i5-4670k
HDD 1: Samsung SSD 250G 840BW EVO
HDD 2: Western Digital WD10EZEX 1TB Caviar Blue 7200rpm
RAM: 16gb (2x8) G. Skill RipJawsX DDR3-2133
PSU: Seasonic X-Series 750W 80 Plus Gold
GPU: Gigabyte GV-N770OC-4GD
CASE: Fractal Design Define R4
OPTICAL DRIVE: Pioneer BDR-209DBK
MONITOR: Samsung S24C300HL; BenQ E2200HD
OS: Windows 10 Professional
Other: MS Wired 600; Logitech MX 310; Sennheiser PC 151 & Logitech Z150
desolator4u
Can't remember exactly where to go. It should be Advanced>APM
You'll see the description for each option, such as S3 or S3+S4. basically one of those options will allow you to disable the LEDs while it's off or in sleep. Doing this will also disable the USB ports when the PC is off.
Look through those options and you'll figure it out.
8700K / Noctua U12S / Maximus X Hero / 2x8GB Corsair Vengeance 3200MHz / EVGA GTX 1080 Ti / Seasonic Prime 650W / 4 x 1TB SSD / 970 Pro 512GB M.2 / Game Zero Headset / K95 Platinum / Logitech G502 / Win 10 x64/ ViewSonic XG2701 1080p 144Hz
