Asus ROG Front Base AAFP Cable ...
DjRavix
I got An Asus ROG Front Base Because I liked it Better Than The OC Panel That Came With My RIVBE
And Also Because of the Higher Quality Front Panel Audio
However the Included AAFP Cable seems to be nice Quality But I am in No way able to connect it because it's so short
I do not know if anybody else has the same problem
But it's quite annoying not being able to connect it in any way because of the short cable
So I would Like to know If There is a way to get another (Longer) Replacement Cable From Asus ???
This Cable would only be usefully in a Mini ITX or Micro ATX Cases
I still think it's silly that Asus included Such a Short AAFP Cable (However it would also Explain the Higher Quality)
ASUS Maximus 13 Extreme
Intel i9 11900K
Corsair Dominater Platinum RGB
Phanteks Enthoo Primo
Samsung 980 Pro 1TB
2 X Samsung 980 Pro 2TB
Corsair AX1200I
EK-Velocity D-RGB - Nickel + Plexi
EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
XSPC RX480 + XSPC RS280
4 X Corsair SP120 PWM OEM Fans
2 X Noctua NF-A14 industrialPPC-2000 IP67 PWM
2 X Noctua NF-A14 PWM chromax.black.swap
2 X Noctua NF-S12A PWM chromax.black.swap
1 X Noctua NF-A15 HS-PWM chromax.black.swap
Praz wrote:
Hello
http://rog.asus.com/forum/showthread.php?47226-ROG-Front-Base-cord-update.&p=401013&highlight=AAFP#p...
Nice ... Thnx
Intel i9 11900K
Samsung 980 Pro 1TB
Corsair AX1200I
Praz
You're welcome. 🙂
