First PCI-E X16 works 1/8 times.
polarbeardav
I'm prett sure that the first PCI-E slot is damaged since it only allows me to boot up once about ever eight times. Using the other slots it works flawlessly, but I shouldnt have to ignore the fact that my MOBO CHF5 is broken. Any ideas before I have to RMA?
Asus Crosshair Formula V
AMD Phenom II X6 1100T BE 3.3Ghz + Swiftech HD H20.320
Corsair Vengeance DDR3 8GB 2X4gb 1600 (clocked at 1333)
Team DDR3 8GB 2X4gb 1333
HIS Raedon HD 6850
Diamond 7970
Thermaltake 775W
Windows 7 Ultimate 64
Switch 810
4 REPLIES 4
NemesisChild
Level 12
When you say it won't boot, does it not post and/or does Windows fail to load?
Just to be certain it's the board, do you have another graphic card to test in the first slot?
Also, if you haven't already, use a can of compressed air to blow out any dust or particles that may be in the slot.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
chrsplmr
Level 18
Good advice from NemesisChild then if not,
Mason @ Asus RMA Guide
Oh, Thanks for your help!
HIS Raedon HD 6850
Diamond 7970
Thermaltake 775W
Switch 810
polarbeardav
So I've thoroughly tested everything out (diff graphic cards, diff slots, diff cpu) and the only problem with the board is that first PCIE X 16 slot. I'm RMAing.
HIS Raedon HD 6850
Diamond 7970
Thermaltake 775W
Switch 810
