Results 1 to 10 of 31
Thread: Z97 Fan Headers
06-06-2014 03:21 AM #1
- Join Date
- May 2014
- Reputation
- 10
- Posts
- 33
Z97 Fan Headers
Hello all,
I was just wondering if all the fan headers are true PWM headers in this generation of motherboards, or if only the CPU headers are, as in the last generation.
06-06-2014 12:45 PM #2
Yes, all headers support both PWM and DC fans.
06-06-2014 09:57 PM #3
- Join Date
- May 2014
- Reputation
- 10
- Posts
- 33
I was referring to the problem described in this thread:http://rog.asus.com/forum/showthread...VI-extreme-z87
06-06-2014 10:31 PM #4
Hello
And as I stated above full control of both PWM and DC mode fans are supported on all fan headers for Z97. There really was no reason for the confusion with Z87. The fan header pinout specifications clearly showed pin 4 PWM control for the CPU fan header only. All other included fan header pinouts had pin 4 at 5V. Armed with this info one should know that PWM functionality was limited to the CPU fan header only.
06-06-2014 10:46 PM #5
Tokens210 PC Specs Motherboard Maximus VI Formula Processor I7-4770K Memory (part number) F3-2400C10D-16GTX Gskill TridentX (8gbx2) Graphics Card #1 EVGA GTX 550TI 1gb Sound Card Supreme FX on board Storage #1 2x Samsung Evo 120gb Storage #2 WD 1TB CPU Cooler Swiftech H320 Case Coolermaster HAF 932 Advanced Power Supply Corsair HX850 80+ Platinum OS Windows 7 64-bit
- Join Date
- Feb 2014
- Reputation
- 25
- Posts
- 517
Just as praz said the new 97 boards support both pwm or voltage control on all fan headers, although if the board has a CPU_opt it may be just a mirror of CPU_fan again if that's what you were referring to
Vi series rog or 87 boards only the CPU fan header has pwm the CPU opt is just a mirror of CPU fan and the rest are voltage controlled, again as praz said
If fans are a concern for you on a build you can always look into a fan controller like a lamptron, should be more then enough to fix most concerns towards fansLast edited by Tokens210; 06-06-2014 at 10:48 PM.
CoolerMaster HAF 932 Advanced/ Maximus VI Formula/ I7-4770K/Swiftech H320/ Corsair HX850/ G.Skill Trident X (2x8) 16gb 2400MHz/ 2x 840 EVO 120gb(Raid 0)/ WD 1TB HDD (Backup/Storage)/ EVGA GTX 1gb 560 TI/ Asus 12x bluray combo
06-06-2014 11:25 PM #6
- Join Date
- May 2014
- Reputation
- 10
- Posts
- 33
06-06-2014 11:33 PM #7
Hello
All fan headers on the Z97 boards are "true" PWM as well as having the option of voltage control for 3 pin fans. I'm not sure how many more different ways there is to state this. Hopefully this is now clear unless you are asking something different than what we are reading.
06-07-2014 12:13 AM #8
- Join Date
- May 2014
- Reputation
- 10
- Posts
- 33
I apologize for the confusion; you stated that one of the four pins on all but the CPU headers is 5V, making the fans plugged into these headers voltage controlled. For items such as externally powered PWM splitters, this allows only the two CPU headers to be used; as the CPU_OPT mirrors the CPU header, using a splitter and a PWM controlled pump is not feasible since the pump's PWM signal requires different ranges then those of the fans. This obstacle is why I referred to these headers as not "true" PWM headers.
06-07-2014 12:38 AM #9
Hello
Please have another look at post #4. I stated that all fan headers on the Z97 boards were PWM capable. Everything I wrote after that in that post was in the past tense directly related to the Z87 post you linked to.
06-07-2014 01:55 AM #10
- Join Date
- May 2014
- Reputation
- 10
- Posts
- 33
