You will most probably need a factory reset, just as @GottiBoi55 said.
I had the exact same symptoms like you yesterday and did this (with ac-adapter installed and battery installed):
HOME (hold) + CTRL (hold) + Power (tap)
It did require me to install my original HDD (my SSD wouldn't work) and a BIOS that I renamed to G46VW.BIN (I downloaded v209 from Asus website) placed in C:\ root.
The screen should magically start up with a blue interface for factory recovery.
I did do it a couple of times till it started.
EDIT: Memory combinations didn't do anything for me.
G46VW | 3740QM @3.7GHz (All cores) | SanDisk 960GB SSD | 16GB Kingston LoVo | GTX 660M | GTX 970 via Thunderbolt
