Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    New ROGer Array
    Jun 2014
    4
    Replacement Keyboard for G750JH Note book?
    I'm wondering if anyone knows a site or reseller where I can get just a replacement keyboard for the model mentioned above.
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,653
    Not sure if that's possible. It'd have to come with the mouse and all, too.. since the keyboard and mouse seem to be joint onto the steel plate.
    ROG Guru: Yellow Belt Array
    Jan 2014
    222
    ebay, believe they're like $150
    ROG Member Array
    Jun 2014
    16
    what is wrong with it?
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    Quote Originally Posted by GetEquipped View Post
    GetEquipped, Asus doesn't seem to offer just the keyboard, but instead the whole top plate with the keyboard - the keyboard is bonded with the top plate, here is the US version from estore.asus.com - pick your country and search for g750 to find the language keyboard for you.
    Replacement Keyboard Module (G750JW, U.S.)
    SKU: 90NB00M1-R31US0
    Your Price: $99.99
    http://us.estore.asus.com/index.php?..._detail&p=6461
    Here are some internal photo's including the underside of the top plate / keyboard:
    http://forum.notebookreview.com/asus...sassembly.html
    New ROGer Array
    Jul 2014
    1
    Will that replacement keyboard plate also work with the G750JX? I just had a couple keys die on me and will have to replace it myself I think. It looks like the same keyboard (and it's the same model basically) but I just thought I should double check.
  7. #7
    hmscott PC Specs
    Jun 2013
    44
    5,357
    Quote Originally Posted by Slarbicus View Post
    Slarbicus, unfortunately the listing only specifies JW, but since the JW came out first, it is likely Asus just didn't update the listing to include the rest of the G750 models - but you should check with Asus to be sure - ask the estore and ask vip.asus.com as a Technical Inquiry.
    All the G750 models appear to have the same top panel/keyboard/trackpad to me, at least on the JW/JX/JH - except my JH has the Assassins Creed logo silk screened on it
    Let us know what Asus says, or if you order it and get it fitted on your JX
  8. #8
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,653
    I'm looking very closely at it. The ribbons are in the right position for the JX as far as I'm aware.
    And yeah, as I said, you won't get the keyboard alone.. you'll have to get the entire plate, which includes the keyboard, mouse and power button.
    P.S. It's an absolute B!TCH to connect the keyboard ribbon.. be VERY sure you've got it slotted in square on before you latch it (seat) after attaching the lights and touchpad.
  9. #9
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,653
    I might actually get one myself, just as a spare.. thinking of modifying my keyboard lighting color to green. Also my mouse left-click on the pad is very loose compared to right click and I do not like that.
    Thanks for the link hmscott, I'll keep it safe somewhere I think. ;x
  10. #10
    New ROGer Array
    Jun 2014
    4
    Thanks for the link, I'll check it out
