Results 1 to 2 of 2
    Bear.dx-t
    Guest
    Debug 34, optical/HD not recognized
    Got all my parts in today and completed my first build today. Everything has went well until I started it up. I'm getting debug 34 but my CPU and ram is showing up fine in the bios with all voltages and timings set to the way they're supposed to be. I've tried using the 6gb sata cable/ports and the 3gb sata ports, even tried enabling hot plug under the ports they were plugged in to. I'm guessing whatever reason is preventing them from being recognized is also why the Boot_Device LED is staying lit.
    Please help @_@
    Nyc_kid
    Guest
    same here on my hdd but the windows 7 picked it up even though bios doesn't
Similar Threads
  1. Optical Drive is Gone
    By brian1121 in forum G Series Gaming Notebooks
    Last Post: 02-02-2012, 05:08 PM
  2. BIOS says 16gb installed, but only 8gb recognized
    By zephyr in forum G Series Gaming Notebooks
    Last Post: 08-27-2011, 01:47 PM
  3. USB 3.0 device not recognized using inner mobo connector
    By Alexia in forum Other Series Motherboards
    Last Post: 08-19-2011, 05:47 PM
  4. Ethernet Controller and others not recognized
    By Sib in forum Other Series Motherboards
    Last Post: 01-06-2011, 12:46 AM
  5. Blue ray disc not recognized
    By jaime628 in forum G Series Gaming Notebooks
    Last Post: 12-16-2010, 01:18 AM
