USB devices are disconnected alone
TheFugas
Hi good afternoon to everyone who you are part of this great forum, today I come to bother you with a little problem that comes torturing me long and is as follows:
- I have a USB keyboard when I'm playing is disconnected, connected only at the time and also the classic sounds of little sound when you remove a USB.
I've tried everything and I quote the solutions I've tried:
1) Change PC Power Plans - Deactivating the automatic suspension of USB
2) Reinstalling drivers (both safe and normal mode)
3) Reinstalling the Chipset drivers and USB motherboard
4) Reinstalling Windows from scratch again.
5) I made a thorough cleaning of records (in Safe Mode)
The keyboard works perfectly if I connect it to my laptop for example.
I hope you can provide me please help.
If you can not be due to lack of power by connecting a second power cable to the motherboard .. Out more try ...: (
A greeting and thanks for your time!
Praz
Hello
Can you test with a different keyboard? It is noted in the motherboard manual that not all current USB device will be compatible with the the Z97 chipset.
TheFugas
Hello Praz! Thx 4 your reply,
Yes! I already tried diffetent keyboards and I have the same problem with all of them 😞
I have to say all the keyboards I tried are kinda old, I have an Asus Maximus Extreme VII motherboard.
Do you have any recommendation?
TheFugas
Do you have any recommendation? 😄
