Hello
I got a problem with my Ares 2
I have installed it in Corsair 350D case, with Maximus VII Gene MB.
It is installed in the first PCI slot.
It is bending a little bit at the end, any1 know what it can be?
Is it cause of the weight of the card, problem with the PCI-E allignment with the brackets which is causing the card to bend?
Can it damage the card in the long run?
Thanks in advance
Cheers
