Results 1 to 4 of 4
    ROG Enthusiast Array
    Dec 2012
    42
    Any Issues with G46VW auto fan control?
    I recently descovered that my sister's laptop had a BIOS problem that didn't allow the fan to go 100% (it's an ACER 5750G) ..... the company has released for some time now an application that allows you to set the fan at full speed).
    Do the G series laptops have these issue? (I have a G46). Does tyhe BIOS allow the fan to go at full speed when necessary?
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,149
    Well are you having an issue with your Fan? We only deal with Asus Gaming Note Books here don't know what to say about your Acer you'll have to deal with that in there forum.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Dec 2012
    42
    I used the Acer as an example. How do we know that the G series laptop can raise the fan speed to 100%? Right now I don't seem to have any heating issues with my G46, but the Acer laptop got me thinking ....
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,149
    Well then look through these thread, generally the only time we see fan problems is when systems are clogged up with dust or the pasting has failed. You can check for update BIOS here in Asus Support Downloads. Fan Speeds are controlled by you mother board there is no separate software that controls the fan speeds
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
