4 LED's on 2-pin IDE_LED connector (HDD activity LED)
upYours101
Hi guys,
I was just wondering if I can connect 4 LED's to the frontpanel HDD activity connector?
No clue what the specs from the LED's are since I salvaged them from an ancient no-name case, but they are all connected to a single 2-wire which gave me the idea to use those on my res in a scratch build.
Does anyone know the max load that header can take?
Would it be possible to power a small LED-strip from the HDD activity connector?
Thanks
5 REPLIES 5
chrisnyc75
Level 12
Not sure, but it shouldn't hurt anything to try. The header is going to provide whatever amount of power it provides, the worst that should happen is that the LED strip won't light up (or will be very dim).
Asus RIVBE • i7 4930K @ 4.7ghz • 8gb Corsair Dominator Platinum 2133 CL8
2xSLI EVGA GTX 770 SC • Creative X-Fi Titanium • 2x 840 SSD + 1TB Seagate Hybrid
EVGA Supernova 1300W• Asus VG278H & nVidia 3d Vision
Phanteks Enthoo Primo w/ custom watercooling:
XSPC Raystorm (cpu & gpu), XSPC Photon 170, Swiftech D5 vario
Alphacool Monsta 360mm +6x NB e-loop, XT45 360mm +6x Corsair SP120
HiVizMan
Level 40
Would not be a problem.
Ok, thanks guys!
Will try it later tonight, still constructing the front now.
upYours101
Works just fine! :cool:
HiVizMan
Level 40
Post a picture or it did not happen mate. 😄
