Results 1 to 10 of 12
Thread: Gpu tweak problem
07-17-2014 05:00 PM #1
Gpu tweak problem
hello
i have asus formula vi mobo and asus gtx 770 2gb gpu and im trying to use ASUS GPU TWEAK to overclock it but my
GPU BOOST CLOCK IS 0000 mhz and i try to change it and push apply it always goes back to 0000mhz , and the memory clock
is at 7010and try to change that to it goes back to 7010 after apply. help anyone
07-17-2014 05:54 PM #2
even tried monitor under load after changes made?
07-18-2014 12:12 AM #3
gpu-z say it only running at x8 v1.1 but it support x16 3.0 , and yes it is in the x16 slot ,
the bios say it is only running at x8 speed,
how can i change this
07-19-2014 12:48 AM #4
07-19-2014 01:05 AM #5
Nate152 PC Specs Motherboard ROG Maximus IX Code Processor i7-7700k 5.2GHz Delidded Memory (part number) 16GB G.Skill Trident Z 4025MHz 17-17-17-39-2T Graphics Card #1 Titan Xp - EKFC waterblock Graphics Card #2 Titan Xp Sound Card ROG SupremeFX 2015 Monitor HP ZR30w Storage #1 Toshiba OCZ VX500 256GB CPU Cooler Swiftech Apogee GTZ Case Thermaltake Armor+ VH6000 Power Supply EVGA Supernova 1600w Titanium Keyboard Cyberpower Skorpion K2 Mouse Razer Basilisk Headset Sennheiser HD6XX / Modmic 5 OS Windows 10 Home 64 bit Accessory #1 Asus optical drive Accessory #2 Koolance ERM-2K3U
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,433
Hello dj.gonzales, Welcome to the ROG forum.
Try clearing the cmos and see if that fixes the x8 problem, you can also try reseating your gpu. Look in the bios and see if it has changed to x16.
If you installed the latest Nvidia beta driver 340.43, that is why gpu tweak is reading 0's. Roll back to 337.88 and you will be able to use gpu tweak.
When installing 337.88, do a custom/advanced install and check the box that says perform a clean installation.Last edited by Nate152; 07-19-2014 at 01:19 AM.
07-19-2014 02:59 AM #6
07-21-2014 09:51 PM #7
How did this go dj,g?
07-27-2014 12:58 AM #8
GPU tweak is working but i am still running on x8 speed and not x16 so i dont know what to do.
thanks for you help
07-27-2014 04:36 AM #9
InFAMAS-ONE PC Specs Laptop (Model) N/A Motherboard Rampage V Extreme Processor i7 5960X Memory (part number) Corsair Vengeance 64GB 2400Mhz Graphics Card #1 ROG-STRIX-GTX1080TI-011G-GAMING Graphics Card #2 ROG-STRIX-GTX1080TI-011G-GAMING Monitor ASUS ROG PG278Q Storage #1 Samsung 960 Evo M2 Case Raijintek NYX Pro Power Supply Corsair AX1200i Mouse ROG Spatha OS Win 10 Pro x64
- Join Date
- Apr 2014
- Reputation
- 11
- Posts
- 68
Are you using a Beta driver? I had the same problem of "000 MHz" on my SLI configuration of 2 Poseidon Platinum GTX 780's. It turned out that the problem was with the new Beta driver. As soon as I rolled back to the current WHQL, the problem was resolved. as for only running on 8 lanes, I am unsure. do you have any other PCI-E devices connected to other slots?
07-30-2014 10:46 PM #10
yes I did have the Beta driver be for and i took it out and then it did work, as for the speed x8 , I only use one GPU or I only have in 1 slot and that is the first red one with the PCI-E 3.0 x16 slot no other slot are in use
