Results 1 to 4 of 4
    New ROGer Array
    Jul 2014
    4
    ROG Front base ROG EXT Cable
    Does anyone else ROG EXT cable running from the ROG port on M/B to front base seem loose as hell??
    Where mine connects to the front panel it's ridiculously loose, cant seem to find a way to keep it in, all i have to do is slightly knock my case and its out
    ROG Guru: White Belt Array Sparax PC Specs
    Sparax PC Specs
    MotherboardAsus Maximus Hero VII
    ProcessorIntel Core i7 4790K
    Memory (part number)16GB Corsair Vengeance Pro 2400 MHz (CMY16GX3M2A2400C11R)
    Graphics Card #1Nvidia GTX 560Ti
    MonitorSamsung S24C450
    Storage #1120GB Corsair Force 3 SSD
    Storage #22TB Western Digital Caviar Black
    CPU CoolerCorsair H100i
    CaseSilverstone TJ09
    Power SupplyCooler Master 850W
    Keyboard Qpad MK-80
    Mouse Razer Deathadder 2013
    OS Windows 7
    Sparax's Avatar
    Jun 2014
    13
    95
    Hiya NateHutch
    My ROG EXT cable seems pretty solid mate try taking the Frontbase unit out of your system and make sure you have a solid connection before mounting it to your case if it still seems lose while outside the case you could try using a hot glue gun or some tape to secure the cable.
    Dec 2011
    354
    25,742
    Nate how did this turn out mate?
    New ROGer Array blittenb12 PC Specs
    blittenb12 PC Specs
    Laptop (Model)Asus ROG G73SW-3DE
    MotherboardAsus Rampage V Extreme
    ProcessorIntel 5820k 3.3 GHz 6 core
    Memory (part number)CMD16GX4M4B3300C16
    Graphics Card #1Geforce Titan X 12 GB VRAM
    Sound CardOnbard Rampage Extreme Supreme FX
    MonitorASUS PG278Q ROG Swift 27-Inch Screen
    Storage #1Samsung 840 Evo 1 TB SSD
    CPU CoolerCorsair H110i GT
    CaseCorsair 760T White (ROG color scheme mod)
    Power SupplyCorsair AX860
    Keyboard ROCCAT RYOS MK Pro Mechanical Gaming Keyboard
    Mouse ROCCAT TYON
    Headset ROCCAT KAVE XTD 5.1 Digital Premium
    Mouse Pad Roccat Hiro
    OS Windows 8.1
    Network RouterAsus AC68u
    Mar 2015
    3
    I absolutely agree, both the cables that came with my OC panel and the Front base are extremely loose even without putting the unit in the case. I am going to request a replacement.
