Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Torsten
    Guest
    G53Sw-XN1 Audio Studder
    Hello all,
    I've been lurking the forum for a bit and just recently experienced an issue with my laptop and wanted to throw the issue out here and see if anyone has any ideas.
    The game that I play the most is EverQuest 1, not exactly a demanding game (single threaded app), even in todays MMO standards. I do raid, so the load on the system is a bit more than when out soloing. I also run two log parsing programs.
    Here's the situation. I was preparing for the raid, so the game was basically maxed out as far as graphics usage are concerned. I was also patching EverQuest Beta at about 25Mbit, running both my log parsing programs (1 of them is just a simple log parser for DPS calculations, the other is an audio trigger program to fire off sounds when certain words are saved in the logfile), and also listening to some MP3's with Winamp. I did have a couple of instances where the sound had stuttered for about a second and it seemed like the game may have frozen along with the stuttering.
    It seemed like an I/O issue of some sort, having the hard drive being wrote to by the Beta Patcher, with the combination of an audio trigger firing off from one of my log parsers, in combination with sounds from EverQuest and music from Winamp all happenning at the same time.
    I haven't experienced this issue with my desktop, so I know from a software perspective this should all be fine.
    Desktop system is an i7 930, GTX 470, 4GB DDR 1600, 1TB Samsung Spinpoint F3
    Laptop is just the base G53Sw-XN1, no hardware modifications. The system has been reimaged with a clean Win7 Home Premium 64-bit install, latest drivers for everything except for Bluetooth, Cardreader, Turbo Monitor (installed those off the Asus driver DVD). Running the latest Nvidia Verde Beta Drivers with the modified INF.
    I run RealTemp and MSI Afterburner (for sensor monitors only) in the background.
    Thanks in advance~
    EDIT: I probably should have mentioned, I am running the Realtek Audio Driver 2.65 no Creative or THX applications were installed to enhance the sound device.
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    18
    1,334
    Has this happened more than once? If not, don't worry about it.
    Kicking Ass Since Today
    Torsten
    Guest
    It happened three or four times over the course of about 5 minutes, but never occured through the rest of the night. This was my first night actually gaming with it having everything running and ready to go, so I'll keep my eye (err ..ear) out for it if it happens again, I'll try and provide some more info. Tks!
    ROG Guru: White Belt Array midihooker's Avatar
    Aug 2011
    88
    download this and see if you have any driver issues..
    http://www.thesycon.de/deu/latency_check.shtml
    Im Peter, a G73SW user from sweden
    Torsten
    Guest
    Thanks for the link.
    The monitor was showing mostly yellow with the occassional run of green, some spikes of red amidst the yellow. Certainly more yellow and red than green. I was also running on battery power, so I don't know if that was influencing it or not. I'll dig around a bit more, but I tried disabling all of the devices in device manager that I felt were safe to (all but things like HDD, CPU, Video Adapter, and most of the system devices.), and didn't really see any significant changes.
    Torsten
    Guest
    So it seems that I have a device driver somewhere causing the DPC latency to spike. I'm thinking I may just reimage the system, run that program from the beginning and check it before and after every driver install.
    Either way, I do have another issue that I am running into. I can not get the THX TruStudio software to detect my hardware after installation. I've downloaded the THX TruStudio MUI 1.02 as specificed in the driver sticky post for the [SW] systems over the Realtek 2.65 drivers that I downloaded directly from Realtek's site. I've also tried uninstalling those drivers/softwares, running driversweeper on reboot in safe mode to clean those off, then reinstall the packages directly from Asus website (old old drivers), and still have the same issue.
    Does anyone have any information on how to get the realtek drivers with the THX TruStudio software reinstalled like it was on the factory image? At this point I don't necessarily care if the realtek drivers are current, I would just like to find out how to make this work as I've spent hours trying and it's starting to frustrate me. :/
    Tks~
  7. #7
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Do you have an Atheros WiFi adapter? If so, update the driver to 9.2.1.432
    We REALLY NEED a sticky about this darn Atheros driver!!!!
    Have you tried using the Driver CD for THX and the RealTek driver?
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
  8. #8
    Torsten
    Guest
    Yes. I have the Atheros WiFi module, I was using the 9.2.0.113 driver so I will update that.
    I haven't tried installing the THX and Realtek from the Driver CD, but that's going to be my next stop. Unfortunately I didn't bring that with me to work and I don't see a SW driver DVD ISO here to download, so I'll have to report back on that later this evening.
    Thanks
  9. #9
    Torsten
    Guest
    Atheros drivers have been updated, of course my Realtek and Creative software/drivers are also currently uninstalled but the DPC latency monitor is showing night and day differences! Absolute is now 268 instead of ~5000.
  10. #10
    Aug 2011
    28
    2,224
    That old Atheros driver really wreaked havoc on my system. Mouse/touchpad lag, freezing when browsing online, firefox non-responsive...
    I wound up doing a clean windows install and discovered that the wlan driver was wacked out when I downloaded it over LAN, then installed it. . . Boing! Lagtime again. Didn't know about dpc lapency checker, then.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
Similar Threads
  1. Low Audio on G74SX? Here's the fix
    By Chastity@ASUS in forum ROG Gaming Notebooks
    Last Post: 10-14-2013, 05:01 AM
  2. Audio Popping
    By twinpeaks in forum Other Series Motherboards
    Last Post: 01-06-2012, 09:27 AM
  3. Replies: 3
    Last Post: 12-03-2011, 01:10 AM
  4. HDMI audio
    By brettt777 in forum ROG Gaming Notebooks
    Last Post: 08-11-2011, 04:26 AM
  5. ENGTS250 Audio
    By Sleven in forum Nvidia Graphics Cards
    Last Post: 02-03-2011, 12:42 AM
