Need advice on a new cpu cooler!
CHRISTIAN_MACED
Hello all,
First off my basic Rig Info:
CM Storm Trooper case
Rampage IV Black Edition MOBO
4960x Ivy Chip
16G Ram dual channel(Kingston)
Corsair H100i cooler (which I think is broken)
Asus DCII GTX760 GPU
500G SSD & I TB HD
Corsair 1200 PSU
So I got my PC built for me 4 months and it worked flawless, until recently I noticed really high temps on Corsair link and in core temp.
It went from an idle 30-35c to a 45-50c idle. And at full load (No over-clock) 80c - 85c which I know is not normal.
I have re-applied thermal pasted and re-mounted twice, run everything on stock settings and still reach 90c. (This is playing Tomb Raider 2013 on normal settings)
This lead me to believe that the H100i has failed. All roads were leading to a broken pump. I don't care about RMA's or even trying to fix it. I just want a new cooler that does its freekin job and dosn't crap its pants if/when I overclock.
--->My question is what is the best cooler to date and will it fit in my case??
So far I have looked at CM Nepton 280l and Zalmans Resonator 3
Any suggestions or advice would be great!!
Thanks in advance!
Chris
12 REPLIES 12
abvolt
Level 11
I agree the coolermaster is a really good unit also take a look at the new swiftech h220x very nice..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Thanks for the speedy reply guys!
Nate152 - Guess I was on the right track then, I might just get the Nepton then.
abvolt - You think the H220x will Fit my Trooper case? I really like the look of it, but performance will be KEY. Sorry I am really crap when it comes to figures and dimensions as such. I have a closed case so it not like ill get to look at it much ;(
Nate152
It looks like the H220x would fit in your case. Which ever one you go with post back some pics and results for us please.
I will do indeed Sir.
Thanks again!
HiVizMan
Level 40
Swiftec H220X gets my vote.
randyenergy
Yeah, the Swiftech H220X looks great. Is it advisable to use the same unit for the cpu and graphic card?
XJP05
Christian, if you decide on the Nepton 280L, wait a a bit if you can. CM has updated that model to include quieter fans and also pump / waterblock improvements, but I'm not sure of the release date.Should be soon. Link here.
i7-4790K, Z97-WS, EVGA GTX 780Ti S.C., 16GB G.Skill Trident-X 1866MHz CL8, CM Nepton 140XL, EVGA SuperNova 1000 G2, Samsung 840 EVO 500GB SSD, WD Caviar Black 2TB, Win 8.1(x64), Asus PB-278Q (2560x1440p), Phanteks Enthoo Pro. Tripp-Lite LC1200 AVR. Build Images.
Bored & looking for the next project ... 🙂
I just talked to Coolermaster today and they new nothing about any new updates. I ordered one yesterday online and I'm worried I won't be getting the newer model. Unfortunately it had already shipped. Has anyone heard anything?
Case: CM Styker Mobo: Asus R4BE CPU: i7-4960x, Noctua DH-14 Ram: G.Skill Ripjaws Z 2133 16GB CL 9 GPU: NVidia GTX 1080ti 11GB
SSD: Samsung 850 Pro 256 & 512GB HDD: WD Black 3TB, 500GB & Seagate GoFlex 3TB PSU: Corsair AX1000 KB: Corsair K95 RGB Platinum
Monitor: Alienware AW3418DW Mouse: Corsair M65 RGB Elite, MM800 Polaris RGB OS: WIN10 64
