Results 1 to 5 of 5
    New ROGer Array
    Jul 2014
    2
    G750Js right fan not working?
    Hi I braught a G750 JS less thn a month ago but the right fan while I am facing the screen is not working i put my hand infront of it I dont feel any air coming out or in, is the fan has been damaged? please help
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    Play a game then check if it spins, also that optimus isn't running.
    ROG Member Array
    Jun 2014
    22
    its fine.....
    The right fan is the 870m gpu....which only kicks into action during gpu dependant activity such as gaming. The laptop uses optimus, so mist of the time is using just the intel chip for the display. So test the airflow with a game running or during some rendering....it should kick into action.
    New ROGer Array
    Jul 2014
    2
    Thank you for the reply guys I just checked it its either runnig very slowly or not at all is it normal?
    ROG Guru: Orange Belt Array Prostar Computer's Avatar
    Jul 2013
    11
    462
    Quote Originally Posted by Evan.01 View Post
    Use a monitoring utility, such as HWiNFO. The fan speed increases or decreases based on the temperature. If you see the GPU heating up to around 80 C and you aren't hearing the fan or feeling much air still, you may need to update the BIOS and EC firmware, or the fan or fan controller could be faulty.
    We customize Asus, MSI, and Clevo laptops!
