Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    ROG Guru: Orange Belt Array Symho's Avatar
    Oct 2011
    341
    POPPING AUDIO NOISE ON ASUS G74SX-TZ056V
    I have a problem with my speakers, that playback a noise sound when they are active.
    The italian asistance want take my PC for repair but i have read in this forum there is a solution for this problem. Is thi solution official? I hope that Chastity can answer or other moderator to my question.
    Thanks for all!
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Describe the sound. Is is a fuzzy or buzz when the sound is loud? Like a kazoo?
    Is it an occasional popping sound?
    Do you hear it all the time the speakers are playing? Does bass cause it more that high notes?
    Does this only happen when your wifi is active?
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    Oct 2011
    341
    Quote Originally Posted by JRd1st View Post
    I don't know which is the differance between buzz o fuzzy but i'm sure that is a bass sound, so i don't think is a buzz. This problem happen before an audio source is playback, and in the bios too. I believe that is a supply problem. It is not a Wi-fi noise. HELP!
    Aug 2011
    28
    2,224
    If this notebook is new, return it for an exchange. Let the retailer and Asus have the problem. If you RMA it you may not have a notebook for weeks and when you get it returned you never know what you'll get ...
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    Oct 2011
    341
    Yes it is new but i don't want return back my note for the reason that you have post. So if is necessary i'll do!
    Aug 2011
    28
    2,224
    I didn't know you heard noise in BIOS, too! You may have a bad power brick. Do you hear the noise when on battery only?
    Either way, if you hear noises in BIOS there's a 99% chance it's hardware. Bring it back and get a new one!
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  7. #7
    Oct 2011
    341
    Thank you, I'll do!
  8. #8
    ROG Guru: Yellow Belt Array Yahooligan's Avatar
    Oct 2011
    127
    Quote Originally Posted by Symho View Post
    Thank you, I'll do!
    No, wait! Try this first! Chances are if it's this same issue you'll have the same problem with the replacement.
    http://www.asusrog.com/forums/showth...ll=1#post36096
    Yahooligan
    ASUS G74SX-XR1
  9. #9
    Aug 2011
    28
    2,224
    He says he even hears popping when he's in the BIOS...
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  10. #10
    Oct 2011
    127
    Yes, as did the other poster. The card makes noise when powering on and making sound for the first time after the laptop is powered on, the registry setting I linked to prevents the card from going to sleep and that prevents future "pops" once Windows is booted.
    Yahooligan
    ASUS G74SX-XR1
Similar Threads
  1. g74sx - no hdmi audio
    By Constantine in forum G Series Gaming Notebooks
    Last Post: 04-02-2014, 08:09 PM
  2. Low Audio on G74SX? Here's the fix
    By Chastity@ASUS in forum G Series Gaming Notebooks
    Last Post: 10-14-2013, 05:01 AM
  3. Audio Popping
    By twinpeaks in forum Other Series Motherboards
    Last Post: 01-06-2012, 09:27 AM
  4. g74sx-3de fan noise
    By Caesah in forum G Series Gaming Notebooks
    Last Post: 10-27-2011, 12:40 PM
  5. G74SX clicking noise from speakers, can't get rid off it
    By Hideaki in forum G Series Gaming Notebooks
    Last Post: 09-19-2011, 02:34 PM
