Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array
    Oct 2011
    14
    G74SX Fan Problems
    I just got my G74SX laptop.
    This only happens after a cold start, meaning it has been shutdown for a few hours (over night). On startup the fan makes a load buzzing sound, once it hits the desktop it stops, after the startup I can't get the sound to come back even with a restart or shutdown.
    Anyway I can control the fan manually to test the speeds to see if I can get the noise to come back?
    I run speedfan but I can't control the fan that way, runs around 2500rpm and temps around 55c well playing World of Warcraft.
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    You sure it's the fan and not a cd or dvd in the drive? Those fans should NEVER be loud enough to be considered LOUD.
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    ROG Member Array
    Oct 2011
    14
    I'm 100% it is, when I get home from work I will record the process so you guys can have a better idea of what the hell I am talking about.
    It really isn't a problem, only does it for a short time between BIOS and Windows login screen, and only on a cold start. After that you can't even tell the fans are running.
    My concern is long term problems coming from this.
    Aug 2011
    28
    2,224
    Well, I think you should send it in to get fixed or, if your purchase was recent enough, exchange it for another one. What merely makes a noise now may stop working altogether. Don't let this inconvenience become a real problem!
    Good Luck!
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    btotech.com
    Guest
    can you get this sound to come back on a cold start if the notebook is on its side? meaning lift it up and lay it on its left side.
    then run furmark and keep it on its side. this may actually make the notebook overheat and shutdown (another issue that asus may have had no report of but needs a bios update)
    ROG Member Array
    Oct 2011
    14
    I'll try that this evening and post back with some video feed.
    Last day for in-store exchange was two days ago, same day this all started
    Really would hate to send it in for repair since I've only had it for two weeks and got it for the release of Battlefield 3 (next week). Tryin to figure this out before I'm left with that.
  7. #7
    Oct 2011
    31
    2,916
    There was an owner on another forum that had a loud, mechanical noise coming from the fan and, I believe, the left speaker on his G74. (I don't remember if he said it started immediately or only after he owned it for awhile.) Anyway, he really didn't want to ship it off for service if it was just a matter of a foreign object stuck in the fan or something like that. So he decided to open it up. He discovered a piece of plastic left behind by the installer. It was contacting the fan blades and abutting the speaker box in a way that made it vibrate. Shoddy work! He took that out and everything was fine afterwards.
    No guarantee that it's the same thing, of course, but maybe something is obstructing the fan?
  8. #8
    Aug 2011
    28
    2,224
    I saw that post at NBR, too.
    If everyone fixes their own problems, won't that encourage even more shoddy workmanship?
    EDIT: BUT if everyone takes a picture of the gross defects, and posts them on NBR that may have an effect . . . . nahhh
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  9. #9
    ROG Member Array
    Oct 2011
    14
    I don't think it is something in the fan as it only does it a short time (between BIOS and Login Screen) and only on startups with my laptop sitting shutdown for long periods of time.
    But I'll let you guys draw a better conclusion when I get a video up. Hopefully get out of this office sooner rather then later...
  10. #10
    Aug 2011
    28
    2,224
    Look at THIS post. See that first image? Does it sound like it could be that?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
Similar Threads
  1. g74sx USB 3.0 problems
    By Lorca in forum ROG Gaming Notebooks
    Last Post: 10-13-2013, 01:01 AM
  2. G74SX-XC1 Keyboard / Track-pad problems ?
    By Khublot in forum ROG Gaming Notebooks
    Last Post: 10-18-2011, 06:58 PM
  3. Asus G74sx-xr1 Problems.
    By JoJoDean in forum ROG Gaming Notebooks
    Last Post: 10-10-2011, 08:20 PM
  4. G74sx Brightness Problems
    By Azzazel in forum ROG Gaming Notebooks
    Last Post: 09-26-2011, 11:11 AM
  5. G74SX problems with: TouchPad and Recovery CD
    By Bekarasha in forum ROG Gaming Notebooks
    Last Post: 09-01-2011, 06:14 PM
