Z97 Vii Hero + 4790K Overclock Help
tunc8686
hi guys ,
i'm trying to overclock in BIOS and it's not stabilize. how can i do set for best performans ? :confused::confused:
i've corsair h110 water cooling system on cpu and good air cooling system in case.
28 REPLIES 28
NemesisChild
Level 12
Welcome to the forum!
What CPU overclock have you tried and with what CPU voltage?
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
thank you
4,8ghz and 1,327V
Chino
Level 15
There's only one way to stabilize an overclock. And that is to increase the voltage that the CPU is asking for.
tunc8686
What will I do in the bios settings ?
only change voltage ?
tunc8686
upload bios picture
seanmack
tunc8686 wrote:
hi guys ,
Hi !
As others have suggested, increasing your core voltage is the best place to start. I'm guessing you'll need 1.4-1.45mV on your core to keep it stable at 4.8GHz. My i5 4690K requires 1.46 to be completely stable at 4.8GHz.
I would recommend you lower your Uncore (Cache Ratio) by 100-200 MHz. Leave the voltage on that the same (Auto). Please try both upping your core voltage and lowering Uncore speed until it stabilizes. Keep a very close eye on the core temps above 1.4mV !
Let me know how you go with this.
Kind Regards
seanmack wrote:
Hi !
Kind Regards
Thank you for your information and test you I'm being informative
pstlouis
I use ai suite 3 5 way optimization. I set in the parameters to overclock to 4.6GHz. I obtain that overclock with 1.328V. Anandtech suggest 1.45V for 4.8GHz. Check that out : http://www.anandtech.com/show/8227/devils-canyon-review-intel-core-i7-4790k-and-i5-4690k/2
erix_jansen
I have been fin with a 4760K at 1,3V and 4800 Mhz... untill I did some real benchmarks.... PC restarts. I will hafve to set a high voltage
