Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,670
    Serious design problem/quality control problem with EK Supremacy
    Please see this thread http://rog.asus.com/forum/showthread...l=1#post419867
    I have just received the new Supremacy Evo and guess what. The screws are once again not recessed into the cold-plate!
    I have not tried it yet but I can guarantee when I get home and do it will make contact with 2011 socket!
    I still have not had a 100% satisfactory end to the problems on the Supremacy CPU block with no reply to my attempts to update the RMA almost two months later.
    There comes a point where one's time is worth money so I just decided to get a new block...this could not happen twice right?
    WRONG.
    I was told the reason for previous problem was a wrong screw type
    Attachment 40672
    If this was true why have I received a second block with the same problem?
    This design is problematic...it needs the screws to be countersunk exactly level with cold-plate or they will make contact with 2011 socket and cause bad contact of block with CPU. Idle temps are fine but load are not good. There might be many people out there with this problem and not knowing it.
    On the Supreme HF line the corners were recessed so the screw was completely away from the plane of the cold-plate and could never present a problem.
    the finishing of the block is also terribly rough...you still see the machining lines in the surface not present on previous blocks and mine has a pit in the surface too!!
    Some comment from EK would seem warranted!
    ROG Guru: Blue Belt Array twisted1's Avatar
    Aug 2012
    72
    815
    Arne, my EK supremacy screws do stick out a bit from the cold plate. It's never been a problem since I've never used it on S2011(lost the s2011 studs that holds it in place)
    Mine is like over a year old, I'll get some pictures of it later I'm on my phone atm.
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,128
    pm him and see if he gets on here. i personaly have not seen him on here in some time now.
    Apr 2012
    505
    13,670
    Thanks Twisted1...would be helpful...sure same block on 2011 would have contact deficiency I'd bet.
    kkn, I might try that; though if they are interested in what their customers think they might pop by now and then ;-)
    ROG Enthusiast Array EK_Derick's Avatar
    Jul 2014
    30
    The product manager informed me that the block is designed like this on purpose.
    CPU: Intel Xeon X5680 Motherboard: Asus Rampage III Black Edition GPUs: 4x Asus Matrix 7970 RAM: Corsair Dominator GT 4x4GB PSU: LEPA G1600W + Enermax 600W Case: Silverstone TJ07-B
    Apr 2012
    505
    13,670
    So, the block is designed to standoff the 2011 socket and prevent good contact.
    Thanks for clearing that up EK-Derick
    Difficult to get a good picture but this is the problem
    Attachment 40675
    My previous RMA for the same problem Rok Dolinar told me they sometimes have problem with excess nickel plating in countersink so screw can stand out. Following instructions I removed nickel plating but layer was thin so not the problem.
    After submitting photographs I was told there was a shipment of wrong screws. This was not supposed to be happening. I was sent new cold-plate and different screws
    I have fitted one of the alternative screws to this block...see if you can spot which one
    Attachment 40676
    The design of the Supreme HF was much better in this regard
    Attachment 40677
    Finally, your block might not arrive so pretty as the website shot
    Dins and dents though small are there and milling very evident on surface
    Attachment 40678
    If this is the design then it is flawed. 2011 users should check contact by the four corner screws with 2011 socket...at least on RIVE and RIVBE.
    I will repeat: The block may make contact with TIM and some contact with block but load temperatures will be affected.
  7. #7
    Aug 2012
    72
    815
    I was going to get another ek block for S2011, an acetal one as it matches the ek vrm/pch blocks on the RIVE.
    Looking at your pictures though I think I've changed my mind as my supremacy looks exactly the same as yours Arne.
    I might get an extra set of studs for S2011 and try this one on S2011(can't find the s2011 studs that came with the block)
    Mine obviously doesn't have problems with to much nickel plating. As it's a cooper heat plate.
  8. #8
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    Nice pics you guys, like the copper myself, the worn discolored well used look.
    Arne,
    Is there any way you can set your CPU on something with the block setting on top and get a picture where the screw heads make contact with the CPU showing the gap between the CPU lid and block? Or the block upside down with the CPU setting on the block not making contact, whatever makes the best photo. Very interested to see that
  9. #9
    Apr 2012
    505
    13,670
    Twisted1! Yes, very clear there. I think that even without studs you would be able to check for the problem if you have a 2011 socket and CPU. Use the spread method to apply a real thin layer and even hand holding block on CPU you will notice it does not make contact so much with CPU as with surrounding socket.
    Menthol, it is difficult to get a photo of this in situ on the 2011 block since the VRM is in the way "north", I/O shield in the way "west", rampage lit heatsink in the way "south"...
    Maybe if I remove RAM and 24pin PCIe from east side I can show the screws making contact with socket?....I will give it a go.
    What I can do is show the difference in the contact pattern of the block with the CPU as defined by the contact with TIM...that is very clear. If you use the spread method to make a very thin layer it shows clearly.The point is, that if you use the blob method you will get the block to spread the TIM and your idle temps will be normal but your load temps will be higher than they should be because of course the layer of TIM is thicker than it should be and the contact bad. At 4.4GHz my load temps are 55 max. With bad contact they were reaching 75...so if you don't know what you are looking for you might think your cooling is OK just not great...but of course for OCing the block is useless.
    Bad paint drawing for bad contact...but you get the idea I guess
    Attachment 40796
    Screws properly countersunk
    Attachment 40797
  10. #10
    Apr 2012
    505
    13,670
    I'll post this even if it doesn't quite capture the problem...it is the best I can get without stripping the board of everything
    Attachment 40806
    However if you know the 2011 socket you know that the socket edges are curved and the apparent gap between cold-plate and socket is nothing.
    In fact if you look at
    http://www.intel.co.uk/content/dam/w...2011-guide.pdf
    you can see the IHS of the CPU is virtually level with the socket height. It certainly does not allow for 0.5-0.75mm of screw head!! which these screws have.
    Attachment 40807
    Maximum tolerance there looks to me to be bellow 0.25mm so the design of the waterblock should be: screws flush with coldplate as a maximum or recessed away from the plane better. Pretty basic stuff and a practice followed on all other CPU blocks I can see like the 380i or as pointed out even older EK designs...
