R5E with 5930K and F4-3000C15Q-16GRR GSkill Memory
Hopper64
Level 15
Will R5E with a 5930K work well with GSkill F4-3000C15Q-16GRR? I don't want to purchase memory that won't operate at the advertised speed. Tried GSkill 2800 memory with a 4770K last year and it was a loss due to the IMC on the CPU. Never had a stable system with that memory in that particular machine. So, will this memory clocked at 3000 work OK with the 5930K on the R5E? Thanks.
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
6 REPLIES 6
Chino
Level 15
The ability to run fast memory on this Haswell-E platform still depends largely on your CPU's IMC. As far as the R5E is concerned, it is able to run RAM at this speed and more!
Personally I haven't had the chance to play with the G.Skill kit you mentioned. But from what I've seen so far, Haswell-E CPUs seems to have a beefy IMC.
Hopper64
Level 15
That's reassuring compared to what happened with that 4770K. Hope it works well. Finding the hardware is the trick now. Still limited availability for most of these parts. Thanks for your help.
Menthol
Level 14
Works for me on an X99 Deluxe, at the moment any frequency over 2400 sets the strap to 125, just something to remember, Raja mentioned there may be bios revision to allow the higher freq RAM to run at the 100 strap
Hopper64
Level 15
Is that using a 5930K? It's all on the IMC on the CPU from what I understand. Thanks.
Menthol
Level 14
I have ran it on a 5820, 5930, and 5960, set XMP settings and it works fine on my X99 Deluxe, I have a RVE coming tomorrow
40860
40861
Hopper64
Level 15
Oh, yes, thanks. Appreciate the insight. Most helpful.
