09-03-2010 02:52 PM - last edited on 03-05-2024 06:44 PM by ROGBot
09-03-2010 04:08 PM
09-03-2010 04:18 PM
09-07-2010 10:15 AM
ASUS OC_Support wrote:
I'm not sure exactly what kind of setup or converter you're using but have you already verified that you have the correct output selected in your Windows or Realtek audio settings? For S/PDIF you need to select "Realtek Digital Output" from the Volume Mixer speaker icon in the bottom right hand system tray in Windows.
10-06-2010 01:59 PM
11-16-2010 11:37 PM
11-17-2010 05:22 PM
11-18-2010 04:50 AM
Pyro411 wrote:
Spunkgamer, I've been doing some digging some people are having the issue some aren't. I'm connecting to a Harman Kardon AVR645, my G50Vt worked on it my G1 worked on it, I also went as far as using the fiber cable plugged into my 360 to try on the laptop with the different cable / port & no such luck. Looks like I'll have to send this unit out for RMA soon 😞
11-18-2010 07:58 AM
11-18-2010 09:19 AM
