Need CPU cooler help
Retired
Not applicable
Looking to upgrade my CPU cooler and wondering from you guys what do you use? I am running a i7 980x Extreme proc. and Corsair TR3X6G1600C8D Dominator 6 GB 3 x 2. Want to over clock to 4.0 Ghz with no heat issues. The cooler I have now (Thermaltake i1) has 1 bad connection to motherboard so it is not working as good as it should and needs to be replaced.
In a perfect world I would be able to keep using the north bridge fan. I do not care if it covers the first mem slot.
So, What you you use or recommend?
16 REPLIES 16
pcjunkie209
Zalman makes a good cooler, I think it's the 10x something ... I'll check when I get home and let you know. I have it that's how I know it works pretty good I had on my 965 and idle was low 30s and it has push pull 120mm
"I would rather be gaming!" Grunts-clan.com
[SIGPIC][/SIGPIC]
http://Pcjunkiemods.com
http://c2cmods.com
Retired
Not applicable
I know everyone hates on corsair h50, but being an air replacment, I had my
r3e and r2e 4-4.5ghz stable. 975 or 980
i hear the h70 is great. Though I haven't tested it yet. For an easy plug an play. And for the price and looks, that's what I recommend. To me personally heat sinks cover up the beauty of the motherboard, especially the r3e
Retired
Not applicable
Was just looking at the h70 on amazon. Looks interesting with pretty good reviews.
Retired
Not applicable
You may not get lucky with the Corsair H50. I didn't that's for sure. Though I'm suspect of not mounting it properly. I want an H70 but at the moment, money is in a pinch. From what I hear though. The H50 is a prime piece and has low temps. Average 30-35idle and 55 under load.
pcjunkie209
Ya well h-50 is a good cooler and I am sure h-70 is gonna be better. I had two h-50s and they worked well
[SIGPIC][/SIGPIC]
http://c2cmods.com
Retired
Not applicable
Ok,ordered the h70 from amazon. What is the best thermal paste now? I have some arctic silver 5 lying around, is it still good or is there better?
pcjunkie209
I use OCZ Freeze it cures in like 15 min. Where as a lot of other TC takes like 40hrs or more. Arctic is good but 200hr cure time......lol
[SIGPIC][/SIGPIC]
http://c2cmods.com
Retired
Not applicable
OUCH! 200hr cure time...Geez.
pcjunkie209
Ya! You can look it up on Tom's hardware. There's a couple others with a 200hr cure time.....but don't get me wrong arctic silver has been good to me. 🙂
[SIGPIC][/SIGPIC]
http://c2cmods.com
