Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
  1. #21
    ROG Member Array P3rNoX's Avatar
    Oct 2014
    13
    21
    Built a lid cover for the table with plexi windows too look inside.
  2. #22
    New ROGer Array
    Dec 2014
    1
    Awesome build! Wood is very heavy so hope you don't plan to move often. I like the clear acrylic. Will you paint the desk? I like woodworking and thought about building a Mod with it but decided that metal would be a lot better. Have fun and I will check back.
  3. #23
    Oct 2014
    13
    21
    Quote Originally Posted by Monstrj View Post
    ThX The Desk is in three parts so its not so heavy to move and ATM i don't want to Paint it.
    Because I do not know much about mettal and the father of my wife is carpenter. I have decided to build my desk wooden but i thnik also metal wold be better ;-)
  4. #24
    ROG Enthusiast Array
    Jan 2015
    32
    Quote Originally Posted by naj1991 View Post
    nice clean work, the wood-optic is verry sexy i think... *dont can understand the peoples they make a woodtable and then paint it black... -make it in alu/metal when you do this... ^^ otherwise let!
    Yeh i agree, leaving the wood as is is nice, but i can understand if you want a black desk, and build yourself, you'd still use wood - it's so much easier to work with than metal. unless you're a pro welder :P
  5. #25
    Oct 2014
    13
    21
    First part of the the Bitspower order is arrived
    Many thanks to all of the Bitspower Team.
  6. #26
    Oct 2014
    13
    21
    My newest toy a really huge relief
    Cut and polish the Balancer holder and mount the Balancer in the desk.
  7. #27
    Oct 2014
    13
    21
    Im very happy to present a new sponsor for my build
    Meny Thank's for the Support and special Thank's to Marsha from Monsoon
    Im also very Happy to Present my Homepage
    I Hope you like it and Support my Project on Facebook www.facebook.com/p3rnox.ch
  8. #28
    Oct 2014
    13
    21
    Hello everybody
    I am very pleased that I now probably finally will find some time to continue my project after nearly 3 years. After I had to move apartment twice I am now promoted to store manager and I’m father now
    It is probably drag on for a long time until it is completed but the good news is there is now a lot of new RGB hardware
    Basically, I have also decided to revise the concept of the project because I certainly have barely time for games
    and have no idea how long the project is still drags .
    1. MountBetter LED Strips
    2. bordering the table with Black film
    3. Additional 5mm Plexiglas layer for edge lighting
    4. New motherboard bracket and pump mounting
    5. Finish the water cycle
    6. Finish Kabel Management / Maybe make a Cablemod Order
    Here at first times the new planned water cycle and the new planned Hardware :
    PC Hardware :
    Motherboard : ROG MAXIMUS VIII FORMULA
    CPU: Intel® Core™ i7-7700K Processor
    Grafikkarte: ASUS GTX980-4GD5
    RAM: Corsair Dominator Platinum DDR4
    Powersuply : Corsair HXi1000
    Storage : 2x Samsung EVO 250GB
    WaterCooling Hardware :
    CPU : EK-Supremacy EVO - Nickel (Original CSQ)
    GPU: EK-FC980 GTX - Nickel (Original CSQ)
    RAM : EK-RAM Monarch X4 - Nickel (Original CSQ)
    RES: Phobya Balancer 450 Silver Nickel
    FITTINGS: Monsoon Hardline Premium Chrome
    ADAPTERS : Bitspower Silver shining
    90° Single Rotary / T-Rotary / Mini Valve / Extenders
    TUBING: Monsoon Hardline Acryl Tube 16/13mm
    PUMPS: 4x Aquacomputer Aquastream XT Ultra Version
    RADIATOR: 2x Phobya G-Chager 560
    SENSOR: 2x Bitspower Flow Indicator Silver
    FILTER: 2x Aquacomputer Filter with stainless steel mesh
    CONTROLLER: Aquacomputer Aquaero 6 XT USB Fan Controller
    2x Aquacomputer Farbwerk LED Controller
    FANS: 16x Phobya Nano-G14 PWM Black Silent Edition
  9. #29
    ROG Enthusiast Array KING DRANZER's Avatar
    Nov 2016
    28
    Did you buy the components CPU, GPU SSDs and stuff. If not then would recommend you to wait for 3-4Months as Intel Skylake-X will be out.
  10. #30
    Oct 2014
    13
    21
    Quote Originally Posted by KING DRANZER View Post
    Yes i Have Allredy Buyed the Hardware. I will only use the Desk for some Office Work.
