G20aj swap gpu/mem/
Wishmaker
Hey Guys,
I hope someone can help me out with some info.
What is the MAX MEM i can put in it the G20AJ 16G?
Can I upgrade the GPU from 760 to 970
Bogdan
14 REPLIES 14
toronto699
its better to post in the general hardware forum as not many do not read the GR= Series Forum I have a G30AB
toronto699
its better to post in the general hardware forum as not many do not read the GR= Series Forum I have a G30AB " General Hardware Tweaking Over clocking Forum"
thanks!
X-ROG
Level 15
No part is upgradable sorry. It's designed to be as compact as possible, which means everything is tightly packed. It's also very specifically designed around the power supplies bundled. Trying to take it apart is very difficult and will void the warranty.
A GTX 980 version is in the works.
Any idea when it will become available?
Not true but opening the case voids warranty.
Asus ROG PG348Q Black 34" 3440 x 1440, 100Hz Curved IPS G-Sync 21:9 WQHD Gaming Monitor
2x ASUS GeForce GTX 1080 8GB ROG STRIX OC Edition in SLI
So I bought a G20aj with a GTX745, I want to upgrade this to the GTX 780, where would I buy this card and the double power adapter to power it, Mine only came with 1 power brick? I dont mind voiding the warranty. Thanks in advance.
Bodycount69
Wishmaker wrote:
Hey Guys,
Bogdan
If you YouTube this there's Asus representative there saying t yes you can upgrade GPU and Memory but opening the case voids your warranty.
toronto699
