Results 1 to 2 of 2
    BulletSponge
    Guest
    G53JW sudden BF3 performance issue.
    I was playing the game fine one round getting 45-50 FPS on a mix of Ultra/med, disconnected and when I rejoined another server I was only getting 12-15!!! This is the case in all of my games now. Poor performance across the board. I have my GTX460M oc'd to 800/1600/1500 and never exceed 85 degrees in any game. I have noticed that while a game is running at the low fps I mentioned MSI Afterburner never shows the gpu core temp exceeding @ 54-55. Any ideas? I had a similar problem last night that seemed to correct itself after a bit but did not check to see if other games were affected as well. I am using the latest nVidia driver 285.62.
    ROG Member Array kody7839's Avatar
    Oct 2011
    14
    Have you tried setting it back to stock settings to see what happens?
    When you are getting the low framerates is your coming out of the down clocked state?
Similar Threads
  1. Low GPU performance
    By iraqiboy90 in forum G Series Gaming Notebooks
    Last Post: 09-02-2011, 03:57 PM
  2. G53JW - Aero Lag + sudden shutdown
    By mr_monster in forum G Series Gaming Notebooks
    Last Post: 07-26-2011, 04:10 AM
  3. Asus Rampage III Extreme mobo issue or an GPU issue???
    By plasma23 in forum Other Series Motherboards
    Last Post: 07-06-2011, 10:57 AM
  4. Performance Stuttering on G73
    By Wuzseen in forum G Series Gaming Notebooks
    Last Post: 01-29-2011, 03:16 AM
  5. So There I was... OC'n when all of a sudden... V2-V3 touched me
    By Hpnotiq in forum Overclocking & Tweaking
    Last Post: 08-30-2010, 10:33 PM
