Results 1 to 1 of 1
    New ROGer Array
    Nov 2014
    1
    Question New build with Gryphon z97, stuck on VGA card
    I am going to be building a pc over the coming months using the Gryphon z97 in a Cosair AIR 240 case, and noticed in the manual that Thermal Radar 2 alow for VGA control of "ASUS NVidia 700 Series graphics card only" does this include all 7xx ie the STRIX GTX750TI or the standard 700's. I have done heaps of Google searches without any mention of this feature??? ( the TUF site dosn't even have the Grtyphon z97??)
    and has anyone used it to control their gpu if so is it worth it or just let it do it's own thing??
    Budget:
    Main uses of intended build: HTPC, Light Gaming, Video editing?, upgradeable (long life)
    Previous build information (list details of parts): Q6600.....
    Monitor resolution:1080p
    Storage requirements:4tb+
    Will you be overclocking: yes/no (delete as required) yes (or undervolting)
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): matx with room for gpu + 2x pcie x1 slots
    Extra information about desired system: potental build
    Corsair Vengeance Pro 8GB (2x4GB) DDR3
    Corsair AIR 240
    Intel 240GB SSD
    Asus GRYPHON
    i5-4690K (due to having a Z97)
    Intel Liquid Cooling Thermal Solution
    Corsair RM-550
    ASUS GTX 760
Tags for this Thread
