Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Guru: Yellow Belt Array
    Oct 2014
    234
    Thumbs up G751JT-CH71 + Other Model ISSUES?
    I've been lurking on quite a few G751 related threads, and I've come across the fact that tons of the people who have ordered them have gotten their machines with issues. I've seen everything from:
    • Dead Pixels in the center of the screen.
    • Improper thermal pasting jobs leading to temps of 110 when gaming.
    • Fizzy Sounding, Punched In, Disconnected, and Loose Fitting Speakers.
    • Improperly placed keyboard keys. (Leading to clicking problems)
    • Broken Trackpad Buttons, Misaligned Trackpads. (With Palmrest)
    • etc.
    This is very worrying and I don't see why so many QC issues are arising from this release.
    It's even worse that I've ordered a G751JT-CH71 and will be picking it up Monday... I swear if I have any or even multiple of these issues..
    New ROGer Array
    Jan 2013
    1
    Dude that's a freakin bad news for me!!
    I'm extremely worried now, cause I've ordered not one but TWO G751JT-CH71 (one for me & other for my brother) should be delivered on November 12.
    Please post your experience here as soon as you check it out, I hope you don't face any defects or whatsoever. it would be horrible
    ROG Enthusiast Array
    Oct 2014
    32
    Sorry to here the issues. I got the G751JM from BB and its been great, now issues ......yet
    Mar 2013
    220
    Quote Originally Posted by guvadc View Post
    If you haven't had any problems yet, that's a really good sign The best of luck with it the next few years.
    The King of the north!
    Oct 2014
    234
    I'll be picking up my G751 tomorrow (Sunday), I've marked down all the issues I've seen online and will be checking all of them before I return home.
    If I get a good unit, I'll post about it - it should help, with all this negativity flying around already.
    If not, I'll have to open up an Amazon Return and I'll post about that too...
    Does anyone know about any portable program to stress the GPU/CPU temps? I've seen a complaint about cooling problems leading to temps of 110, so if I can test that with a portable program, that would be beyond great,
    Mar 2013
    220
    Quote Originally Posted by BRSxIgnition View Post
    Just download MSI afterburner and play a game like BF4 for 20-30mins on a 64player map - That should tell you if it's running too hot or not You will be able to track the temperatures of the CPU and GPU while playing.
  7. #7
    Oct 2014
    234
    Quote Originally Posted by Sagi View Post
    Thing is, I am picking it up, testing it in a coffee shop for about an hour or so, then taking it home if it's alright. I don't want to drive more than an hour to my pickup location, drive home, then realize things don't work.
    Are there any portable utilities I can use to test how high the GPU temps will get at load? (Something to put on a USB stick, then quickly copy onto the machine and run)
    Would the Unigine Heaven / Valley Benchmarks work?
  8. #8
    ROG Member Array Ginseng's Avatar
    Oct 2014
    14
    Hello, I'm not sure if this is a website or what.. check this video and look at how they measure the temperatures, I hope it helps... http://www.youtube.com/watch?v=htgAF...MFk5UtIDimr6hQ
  9. #9
    Mar 2013
    220
    Well, it's better than nothing I guess Perhaps try furmark, even tho it can toast your GPU if it runs too long.
  10. #10
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    BRSxIgnition, hope this isn't too late, but yes the Unigine Heaven will heat up the GPU, Furmark is a bit more directed toward finding heat issues - it has a 15 minute burn-in button configured for max heat generation.
    For the CPU I always use Prime95 8 cores FFT test. It runs without throttling on a well made G750 series, so it should do the same on the G751.
    http://www.mersenne.org/download/#download
    And, to watch the temps I use 2 programs. hwinfo64 Sensors only mode for CPU/GPU and GPU-Z Sensors tab for GPU only.
    hwinfo64 download
    http://www.hwinfo.com/download.php
    GPU-Z ROG version download
    http://www.techpowerup.com/downloads...asus-rog-skin/
    You can leave those run during benchmarks / stress tests and look for throttling in the hwinfo - errors in GPU-Z - hwinfo64 will also log to a file.
Name:	hwinfo64 sensors view.JPG
Name:	intelburnin hwinfo.JPG
Name:	gpu-z cuda msi oc run.JPG
Name:	heaven 4.0 g750jh 1.JPG
    Please come back and let us know how your new G751 tests
