Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
  1. #11
    ROG Member Array
    Nov 2014
    20
    hi chino tks for the reply do u know any site that can guide me to overclock my rampage v ? :P
  2. #12
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Raja wrote an overclocking guide with the new Haswell-E CPUs and the Rampage V Extreme. It is linked in my signature.
  3. #13
    ROG Member Array
    Nov 2014
    20
    tks a lot chino i will chk it out
  4. #14
    ROG Member Array
    Nov 2014
    20
    i tried the guide no luck i still get the blue screen sometimes it gives me AE qcode and 99 i don't know what is wrong with my system
  5. #15
    Oct 2012
    339
    15,255
    If you're unable to enter Windows or experience BSODs, you need to increase your vcore in most situations. Also keep an eye on your temperatures.
  6. #16
    ROG Member Array
    Nov 2014
    20
    u mean cpu core voltage? i did that to 1.5 n still bsod
  7. #17
    Oct 2012
    339
    15,255
    Please read Raja's guide carefully and don't just go and put 1.5V for your Vcore.
    With your configuration, you shouldn't go over 1.25V like the guide has stated. One because your H105 is up for the job and two because your 760W PSU is pretty much on the edge and might not be able to supply your system with enough power.
    Also make sure to connect the 8 pin and 4 pin power cables to the motherboard and have active cooling over your VRMs during stress testing.
  8. #18
    ROG Member Array
    Nov 2014
    20
    ah oky tks a lot i will try with 4 pin connecting to the motherboard
  9. #19
    ROG Member Array
    Nov 2014
    20
    no luck been trying to overclock but all i get is bsod, i cant even use xmp profiles it just crashes
  10. #20
