Results 1 to 8 of 8
    ROG Member Array
    Nov 2014
    9
    Most advanced CPU closed Permanent cooling Ever
    It's Named as Cryo-TEC Cooling System
    http://www.digitalstormonline.com/cryo-tec.asp
    So was asking will asus relate ?
    Will Team ROG ever think of making the most advanced CPU Cooling system ?
    Can it be ever applied to GPU's ?
    According to DigitalStorm it was discontinued to be applied with their gaming rigs , that's so weird and was replaced with a less advanced and less efficient cooling Named as Hydro-Lux cooling system
    so will Asus ever thinks of making Closed CPU cooling system like Corsair H110 ...etc ?
    Helium Chilled Array _ PC Specs
    _ PC Specs
    Laptop (Model)G46VW
    MotherboardRampage IV Gene
    ProcessorIntel Core i7-3930K
    Memory (part number)Corsair Dominator Platinum 32GB (CMD32GX3M4A2133C9)
    Graphics Card #1ROG Matrix GTX 780 Ti
    Sound CardROG SupremeFX III
    MonitorASUS VG248QE with GSync mod
    Storage #1Plextor PX-M2 SSD 120GB
    Storage #2G.Skill Phoenix Blade 480GB PCIe SSD
    CPU CoolerCooler Master Seidon 240M
    CaseCooler Master HAF-X
    Power SupplySeasonic X-750
    Keyboard Corsair K90
    Mouse ROG Gladius
    Headset ROG Orion
    OS Windows 8.1 Update 1
    Network RouterASUS RT-AC66U
    _'s Avatar
    Dec 2011
    119
    5,750
    We're not considering making liquid coolers sorry.
    TEC systems can be applied to GPUs but you have to have a specially designed waterblock, cold plate and mounting mechanism to work with it, which increases the size and weight of the device, meaning you have to brace the card and use no other PCIE expansion cards.
    ROG Guru: Brown Belt Array Antronman's Avatar
    Dec 2013
    29
    1,374
    What MarshallR mentioned, makes for a complicated and specialized manufacturing process, which in turn makes for a very expensive one.
    Not enough profit, slows down production etc.
    Say hi to the next generation.
    Peace is a lie, there is only Passion
    Through passion, I gain strength
    Through strength, I gain victory
    Through victory, my chains are broken
    The Republic of Gamers shall free me
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Companies are engineering new TEC-based products and wading them out to new market niches. Liquid cooling was once exotic DIY stuff, limited to the crazy elite, now it's common fare for enthusiasts and professionals, a standard option in mainstream prebuilt systems.
    I'm hoping that some good TEC toys will appear in coming years. I'm not quite an innovator, but I am an early adopter.
    But TEC consumes a lot of power, and - one way or another - all those Watts have to glow off rads and be blown away with fans. A downside on TEC which concerns me is that when electrical power is shut off (or just fails) the "cold" plate reaches equilibrium with the "hot" plate, meaning that all the heat pulled away from the CPU/etc gets dumped right back. A lot of thermal energy, considering one side can be sub-zero while the other side is hotter than max TDP. I don't think exposing silicon to such sudden and extreme temp shifts can be good.
    ROG Guru: Platinum Belt Array Rockford's Avatar
    Jan 2012
    217
    6,208
    You will be needed to insulate parts of you HW, if you are going to use a TEC cooling solution.
    >> Don't worry, the CPU socket is fully insolated from condensation.
    Worry!!
    ROG Member Array Esmea PC Specs
    Esmea PC Specs
    MotherboardCrosshair VII Hero (Wi-Fi)
    ProcessorAMD Ryzen 3900X
    Memory (part number)64GB G.Skill TridentZ RGB 4x16GB F4-3000C14Q-64GTZR
    Graphics Card #1ASUS R9 390X DC2OC
    Monitor2x Monoprice 2560x1440 Freesync 240Hz
    Storage #1Samsung 960 Pro M.2 500GB
    Storage #24TB WD Black
    CPU CoolerAMD Wraith Prism
    CaseThermaltake Core V71
    Power SupplySeaSonic 1050W PlatinumPlus
    Keyboard Logitech G510s
    Mouse Logitech G903
    Headset Monoprice Wireless BT
    Mouse Pad Logitech PowerPlay
    Headset/Speakers Creative 2.1
    OS Win10 Pro
    Network RouterASUS ROG Rapture GT-AC5300
    Mar 2015
    12
    Quote Originally Posted by Korth View Post
    That's the catch with nearly all forms of PC cooling (LN2 being a slight exception): it's all about moving energy away from the source. Even phase-change systems are victim to this law of physics; they use compression energy transfer to literally force the thermal energy out of the transfer medium. TEC systems require a secondary thermal transfer mechanic to dissipate the hot plate, otherwise it's merely a timebomb attached to your CPU/GPU... once the TEC fails, the heat will build up even faster in the processor. If implemented correctly, the hot plate should not get very hot at all, and in turn the inverse with the cold plate, thus reducing the temperature delta between the two... this is entirely dependent upon the secondary cooler's ability to wick the heat off the hot plate. TEC is more of a safety net in regard to its relation with the processor: it acts as a buffer between processor and the secondary cooler.
    Interestingly enough, my exposure to exotic cooling was the reverse of most people. I learned of TEC in the early 90s, and then Phase-change (I was very very close to buying a Prometheus in 2004, but decided to get a gaming laptop since I was active duty military at the time), then oil-immersion, then water when some of the first kits appeared in the early 2000s. I've always considered water the most dangerous of exotic cooling. I'd rather toss my system in a fishtank of oil, honestly.
  7. #7
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    Oils make a really nasty mess, Midel 7131 is so much cleaner. And, hmmm, a vapor point of 49C, I wonder if it would make a useful refrigerant?
    TECs can reduce temps below ambient, to subzero and beyond if you pump enough power into them. Condensation is a problem. Frost can be a problem. You might need to stick your computer into a dry box, or laminate your components with an electronic-grade clear coat, and you might even need to kick in all those little features Asus adds to combat "cold bugs".
    I suppose you could avoid a lot of that by using a TEC engineered to operate exactly within the proper temperature ranges, not too strong, not too weak. And it would need to self-regulate in response to constant real time fluctuations in thermal stress/loading. It seems like a lot of work, not the sort of thing you could run "unattended" (like air or water) for months at a time, I think it's just as exotic as breaking out the LN2.
  8. #8
    ROG Guru: Elusive Ronin Array SinisterDev85 PC Specs
    MotherboardMaximus Vi Hero
    ProcessorIntel i7 4790k @ 4.8ghz
    Memory (part number)G.Skill Trident X 16GB F3-2400C10D-16GTX
    Graphics Card #1MSI 970 GTX 4GD5T OC
    Sound CardOnboard
    MonitorSamsung JU6500 UHD TV
    Storage #1Samsung 850 Evo SSD x2
    CPU CoolerThermaltake Water 3.0 360mm
    CaseThermaltake Core V51
    Power SupplyEVGA SuperNova G2 750w
    Keyboard Corsair Vengeance K70
    Mouse Evga Torq 10 carbon
    Mouse Pad Steel Series
    OS Windows 10 Pro 64bit
    Network RouterAsus Rt-AC3100
    SinisterDev85's Avatar
    Sep 2014
    11
    301
    Quote Originally Posted by EgyOC View Post
    Holy wow! How does it lower the temps to below 0 on a liquid system like that?! I must know the science behind it! Ive never heard of a cold plate building up frost like what you'd see on a LN2 system.... What's making the liquid so cold? It doesn't look like anything out of the ordinary in the pics..
    ASUS ROG Maximus 8 Hero Alpha | Intel i5 6600k @4.7ghz | G. Skill Trident Z 16gb @ 3499mhz | Samsung 950 Pro NVMe 512gb | ASUS Strix GTX 1070 OC | EVGA Supernova G2 1300w | Windows 10 Pro x64
