1.35V memory required in G751/G771/G551s (same as G750)
X-ROG
Level 15
Please note we fit 1.35V memory into the G751s (and G750s). Haswell CPUs require this and using 1.5V memory can sometimes cause problems along the lines of:
> Overheating
> Damage to the CPU IMC (due to the increased potential difference)
> Greater battery use than our stated values.
There is more discussion and recommendations of memory to use in this thread, as both G750 and G751's use the same Intel 4th Gen 'Haswell' processors: http://rog.asus.com/forum/showthread.php?33744-Upgraders-1-35V-memory-is-required!
151 REPLIES 151
th3l34sh
Is this one okay?
th3l34sh wrote:
Is this one okay?
th3l34sh, it's good to post the actual info, rather than just a link, as those listings change over time. Here is what I found there:
Kingston Technology 8GB 1600MHz DDR3L (PC3-12800) 1.35V Non-ECC CL11 SODIMM Intel Laptop Memory KVR16LS11/8
Are you intending on replacing all 4 SODIMM's? If so then yes, those could be ok, but unless someone posts that they have tried these specifically, then it is unknown. I am concerned that the specifications pdf says it has both SPD 1.5v and 1.35v, they don't say which model/configuration has which - you want the 1.35v SPD - as that is what is required by the G751 Haswell CPU.
http://www.kingston.com/datasheets/KVR16LS11_8.pdf
You need to make sure the SPD of any memory is set to 1.35v, not simply tested as compatible with 1.35v. If the SPD is set to 1.5v then the G751 will run at that voltage, which can damage the CPU.
If you want to add SODIMM's to what your laptop comes with, you want to use CPU-Z to find out what is installed, and buy the same make/model for best compatibility. If you have 4GB SODIMM's that came with the laptop and want to use 8GB's for the 2 open slots, then you can google the make/model of the 4GB's to find the 8GB model in the same family, those are also compatible.
It is a hit or miss situation when mixing brands even if the spec's listed suggest they are compatible. If you check the other thread, many have had problems and after trying something else first and fail, they then check what they have installed and order more of the same and run aok.
The G750 can run higher speed SODIMM's, tested up to 2133mhz, at their full speed, so if you are going to replace all 4 SODIMM's you might as well get a performance boost too. A number of G750 owners reported these work at 2133mhz, you could try them in the G751:
G.SKILL Ripjaws 32GB (4 x 8G) 204-Pin DDR3 SO-DIMM DDR3L 2133 Laptop Memory Model F3-2133C11Q-32GRSL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231776
Those won't mix with what comes with the G751, but if you plan on replacing all 4 SODIMM's they are a great choice.
Please post a snipping tool image of your CPU-Z Memory and SPD tab's showing the memory that came with your laptop. It looks like this:
43339
43340
Solaran_X posted in another thread:
G751JM and Samsung 840 EVO SSD
http://rog.asus.com/forum/showthread.php?53721-G751JM-and-Samsung-840-EVO-SSD&p=450747&viewfull=1#po...
...that he had this memory installed from Asus:
2x4GB Kingston ASU16D3LS1KFG/4G
What do you have installed?
I can't find a spec sheet on the ASU16D3LS1KFG/4G, it is a special build for Asus, but it might be that Kingston you found, if it runs at 1.35v, might be a good fit 🙂
You could order it and give it a shot, and please come back and let us know the results 🙂
Boaz_Beatz
hello i'm buying the g751 with 8gb of ram in it and i want to upgrade it so my question is do i buy two 8 gb sticks or one 16 gb? or do i buy 4 sticks? with 4gb in them
also what kind should i buy? should i buy the same that is already in the laptop or buy a new kind of memory modules ?
also please state what the current 8 gb memory is in the laptop as i cant find that info anywhere on the net the one i'm looking at is Asus G751JT-T7036H also u might ask why i'm not buying one with 16 gb? well they only sell 8 gb versions in sweden
The memory in each laptop can be different so it's best to wait until you get it and match exactly what your particular laptop has. I had two G751JT and so far both had Hynix memory HMT41GS6AFR8A-PB 8GB PC3L 12800S x2.
As for the 8GB model I'm not sure if that one comes with 2x4 or 1x8gb. If it's 1x8GB I believe you need a service center to install the 2nd stick in the 2nd dimm slot that isn't user serviceable. If its 2x4GB then both of those will be installed in the un-serviceable area and leave you with 2 slots you can service.
boombaby_rm31
which memory is safe to use for g551? I WANT TO UPGRADE TO 16GB
Well, I know nothing about memory, but by reading this thread, I figured out 5 key aspects:
1) It is best to match your stick, by not doing so, you can get incompatibility problems
2) The easyest way is to match your current sticks, find out what it is and buy the exact same.
3) The hard way is to remove your current sticks and buy a replacement. hm scott recommands the following:
G.SKILL Ripjaws / 204-Pin DDR3 SO-DIMM DDR3L 2133 Laptop Memory Model F3-2133C11Q-32GRSL
4) It has to be 1.35v and 204 pin
Mublur
I bought: Kingston HyperX Impact 16 Gt (2 x 8 Gt) DDR3L 1866 MHz CL10 SO-DIMM Low Voltage
works perfectly, ran memtest86 and checked that it runs at 1,35v
Mublur, what make/model of memory did your G751 come with? That way people know what the compatibility pairing is.
Thanks Mublur!
Thanks Mublur!
Howdy hmscott, the preinstalled memory is: Hyundai HMT41Gs6aFR8A-PB, 8gb, pc3-12800
